Schieberegler: Schleifspur nach dem neuesten Chrome-Update auf Android zu klein.
    Nach dem neuesten Chrome-Update auf Android wird der Schieberegler in EDOMI falsch dargestellt.
    In der Datei /usr/local/edomi/www/admin/vse/13_vse.php
    function slime(fgcolor,pos,para) {
            if (size.o==0) {
                if (obj.dataset.var3&1) {
                    return "<line x1='"+pos+"' y1='"+(svgHeight/2)+"' x2='"+(svgWidth/2+svgWidth/2*para.size/100)+"' y2='"+(svgHeight/2)+"' stroke-linecap='"+((para.cap==2)?"round":"butt")+"' stroke='"+fgcolor+"' stroke-width='"+(svgHeight*para.width/100)+"' vector-effect='non-scaling-stroke' fill='none'/>";
                } else {
                    return "<line x1='"+pos+"' y1='"+(svgHeight/2)+"' x2='"+(svgWidth/2-svgWidth/2*para.size/100)+"' y2='"+(svgHeight/2)+"' stroke-linecap='"+((para.cap==2)?"round":"butt")+"' stroke='"+fgcolor+"' stroke-width='"+(svgHeight*para.width/100)+"' vector-effect='non-scaling-stroke' fill='none'/>";
            } else {
                    return "<line x1='"+(svgWidth/2)+"' y1='"+pos+"' x2='"+(svgWidth/2)+"' y2='"+(svgHeight/2+svgHeight/2*para.size/100)+"' stroke-linecap='"+((para.cap==2)?"round":"butt")+"' stroke='"+fgcolor+"' stroke-width='"+(svgWidth*para.width/100)+"' vector-effect='non-scaling-stroke' fill='none'/>";
                } else {
                    return "<line x1='"+(svgWidth/2)+"' y1='"+pos+"' x2='"+(svgWidth/2)+"' y2='"+(svgHeight/2-svgHeight/2*para.size/100)+"' stroke-linecap='"+((para.cap==2)?"round":"butt")+"' stroke='"+fgcolor+"' stroke-width='"+(svgWidth*para.width/100)+"' vector-effect='non-scaling-stroke' fill='none'/>";
    ersetzen durch
            if (size.o==0) {
                    return "<line x1='"+pos+"' y1='"+(svgHeight/2)+"' x2='"+(svgWidth/2+svgWidth/2*para.size/100)+"' y2='"+(svgHeight/2)+"' stroke-linecap='"+((para.cap==2)?"round":"butt")+"' stroke='"+fgcolor+"' stroke-width='"+(svgHeight*para.width/100)+"' fill='none'/>";
                } else {
                    return "<line x1='"+pos+"' y1='"+(svgHeight/2)+"' x2='"+(svgWidth/2-svgWidth/2*para.size/100)+"' y2='"+(svgHeight/2)+"' stroke-linecap='"+((para.cap==2)?"round":"butt")+"' stroke='"+fgcolor+"' stroke-width='"+(svgHeight*para.width/100)+"' fill='none'/>";
            } else {
                    return "<line x1='"+(svgWidth/2)+"' y1='"+pos+"' x2='"+(svgWidth/2)+"' y2='"+(svgHeight/2+svgHeight/2*para.size/100)+"' stroke-linecap='"+((para.cap==2)?"round":"butt")+"' stroke='"+fgcolor+"' stroke-width='"+(svgWidth*para.width/100)+"' fill='none'/>";
                } else {
                    return "<line x1='"+(svgWidth/2)+"' y1='"+pos+"' x2='"+(svgWidth/2)+"' y2='"+(svgHeight/2-svgHeight/2*para.size/100)+"' stroke-linecap='"+((para.cap==2)?"round":"butt")+"' stroke='"+fgcolor+"' stroke-width='"+(svgWidth*para.width/100)+"' fill='none'/>";
    vector-effect='non-scaling-stroke' wird entfernt.
    Danach wird der Schieberegler in Chrome bzw. in der PWA wieder korrekt dargestellt und funktioniert wie gewohnt.
    image.png​
    um was für einen Schieberegler handelt es sich denn? Ist das der Schieberegler-Schleimspur VSE1006?
      hab es verstanden....das ist der "hauseigene" Schieberegler....
