Anleitung ist ja wie folgt:
Ich habe ein jungfräuliches Raspi3 und nur rudimentär Ahnung von Linux bisher. dpkg-buildpackage -b -uc -d und dpkg-buildpackage -d bringen den gleichen Fehler.
HTML-Code:
# Do not use "sudo" unless told to do so. # If "dpkg-buildpackage" complains about missing packages # ("Unmet build dependencies"): install them # (apt-get install …) and try that step again. # If it wants "x | y", try just x; install y if that doesn't work. # Also, if it complains about conflicting packages, remove them (duh). # first, install build tools and get the source code sudo apt-get install git-core build-essential git clone https://github.com/knxd/knxd.git # now build+install knxd cd knxd git checkout master dpkg-buildpackage -b -uc # To repeat: if this fails because of missing dependencies, # fix them instead of using dpkg-buildpackage's "-d" option. cd .. sudo dpkg -i knxd_*.deb knxd-tools_*.deb # … and if you'd like to update knxd: rm knxd*.deb cd knxd git pull dpkg-buildpackage -b -uc cd .. sudo dpkg -i knxd_*.deb knxd-tools_*.deb
HTML-Code:
pi@raspberrypi:~/knxd $ sudo apt-get install Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
