Install Error auf Debian Stretch (armhf)
    habe gerade den aktuellen Master branch auf Debian Stretch (armhf) gebaut und bin in folgende etwas ominöse Fehlermeldung bei der Installation gelaufen:
    root@home:/home/rd/git# dpkg -i knxd_*.deb knxd-tools_*.deb
    Selecting previously unselected package knxd.
    (Reading database ... 97809 files and directories currently installed.)
    Preparing to unpack knxd_0.14.16-1_armhf.deb ...
    Unpacking knxd (0.14.16-1) ...
    Selecting previously unselected package knxd-tools.
    Preparing to unpack knxd-tools_0.14.16-1_armhf.deb ...
    Unpacking knxd-tools (0.14.16-1) ...
    Setting up knxd (0.14.16-1) ...
    Adding group `knxd' (GID 123) ...
    Done.
    Adding system user `knxd' (UID 116) ...
    Adding new user `knxd' (UID 116) with group `knxd' ...
    Creating home directory `/var/lib/knxd' ...
    Created symlink /etc/systemd/system/multi-user.target.wants/knxd.service → /lib/systemd/system/knxd.service.
    Created symlink /etc/systemd/system/sockets.target.wants/knxd.socket → /lib/systemd/system/knxd.socket.
    Job for knxd.socket failed.
    See "systemctl status knxd.socket" and "journalctl -xe" for details.
    knxd.socket couldn't start.
    Setting up knxd-tools (0.14.16-1) ...
    Processing triggers for systemd (232-25) ...
    Processing triggers for libc-bin (2.24-11+deb9u1) ...
    root@home:/home/rd/git# systemctl status knxd.socket
    ● knxd.socket - KNX Daemon (socket)
    Loaded: loaded (/lib/systemd/system/knxd.socket; enabled; vendor preset: enabled)
    Active: inactive (dead)
    Listen: /var/run/knx (Stream)
    [::]:6720 (Stream)
    Jul 05 07:38:10 home systemd[1]: knxd.socket: Socket service knxd.service already active, refusing.
    Jul 05 07:38:10 home systemd[1]: Failed to listen on KNX Daemon (socket).
    knxd scheint aber zu laufen (obwohl nicht konfiguriert):
    ● knxd.service - KNX Daemon
    Loaded: loaded (/lib/systemd/system/knxd.service; enabled; vendor preset: enabled)
    Active: active (running) since Wed 2017-07-05 07:38:10 CEST; 1min 2s ago
    Main PID: 370 (knxd)
    Tasks: 1 (limit: 4915)
    CGroup: /system.slice/knxd.service
    └─370 /usr/bin/knxd -e 0.0.1 -E 0.0.2:8 -u /tmp/eib -b ip:
    Jul 05 07:38:09 home systemd[1]: Starting KNX Daemon...
    Jul 05 07:38:10 home systemd[1]: Started KNX Daemon.
    root@home:/home/rd/git# ps uaxwww|grep knxd
    knxd 370 0.0 0.0 6244 1864 ? Ss 07:38 0:00 /usr/bin/knxd -e 0.0.1 -E 0.0.2:8 -u /tmp/eib -b ip:
    root 768 0.0 0.0 3768 576 pts/0 S+ 07:41 0:00 grep knxd
    knxd stoppen, knxd.socket restarten, knxd wieder starten.
    DistKV, Home Assistant, 1wire, KNX, Python, Asterisk, SMD-Lötkolben
      Ok, ich wollte nur sicherstellen, dass Dir bekannt ist, dass
      mit einer Fehlermeldung endet, was für mich überraschend war.
