Logging Konfigurieren
    ich finde im Journal viele Einträge der Form
    Nov 17 23:16:23 home knxd[764]: Layer 6 [10:A.unix/local 2.062] is OK
    Nov 17 23:16:29 home knxd[764]: Layer 6 [10:A.unix/local 8.062] is OK
    Nov 17 23:16:35 home knxd[764]: Layer 6 [10:A.unix/local 13.971] is OK
    Nov 17 23:16:35 home knxd[764]: Layer 6 [10:A.unix/local 14.061] is OK
    Nov 17 23:16:41 home knxd[764]: Layer 6 [10:A.unix/local 20.060] is OK
    Nov 17 23:16:47 home knxd[764]: Layer 6 [10:A.unix/local 26.062] is OK
    Nov 17 23:16:53 home knxd[764]: Layer 6 [10:A.unix/local 32.069] is OK
    Nov 17 23:16:59 home knxd[764]: Layer 6 [10:A.unix/local 38.168] is OK
    Nov 17 23:17:05 home knxd[764]: Layer 6 [10:A.unix/local 44.168] is OK
    Nov 17 23:17:10 home knxd[764]: Layer 6 [10:A.unix/local 49.347] is OK
    Nov 17 23:17:11 home knxd[764]: Layer 6 [10:A.unix/local 50.168] is OK
    Nov 17 23:17:12 home knxd[764]: Layer 6 [10:A.unix/local 50.659] is OK
    Nov 17 23:17:13 home knxd[764]: Layer 6 [10:A.unix/local 51.931] is OK
    Damit ist knxd der bei weitem gesprächigste Dienst auf meinem System.
    Lassen sich diese irgendwie abstellen?
    Danke und Gruß
    Rainer
    Wie hast Du denn den knxd konfiguriert? knxd.ini? knxd.conf?
      Das ist ein Trace-Eintrag. Wenn der knxd funktioniert, wieso hast du Debugging an?
      DistKV, Home Assistant, 1wire, KNX, Python, Asterisk, SMD-Lötkolben
        Ich sehe in der Konfig leider nicht, wo ich debugging einschalte (?)
        rd@home:/etc$ cat knxd.conf
        # configuration for knxd.service
        #KNXD_OPTS="-e 0.0.1 -E 0.0.2:8 -u /tmp/eib -b ip:"
        #KNXD_OPTS=" -f9 -t 0xffe -e 1.1.227 -E 1.0.228:8 -t 65535 -u /tmp/eib -B single --send-delay=70 -b ipt:192.168.0.17"
        KNXD_OPTS="-e 1.1.227 -E 1.1.228:8 -t 65535 -u /tmp/eib -B single --send-delay=70 -b ipt:mdt"
        # The default options are "-u /tmp/eib -b ip:"
        # which tell knxd to route between all of
        # /tmp/eib (legacy socket (-u))
        # multicast client (-b ip.
        # knxd's own bus address is 0.0.1; it will assign 0.0.2…0.0.9 to clients.
        # The knxd.socket file also tells knxd to listen to
        # /run/eib (socket activation via systemd)
        # TCP port 6720 (socket activation via systemd)
        # You *need* the -e option. Clients cannot connect without "-E".
        # You can read knxd's logs with
        # $ journalctl -u knxd --since "10 min ago"
        # (or whatever). See the manpage for details.
        # You need to be a member of the "adm" group.
        # Add "-f9 -t1023" to the beginning of the command line for extensive logging.
        # *** DO NOT use "-u" / "-u /run/knx" or "-i" / "-i 6720" here.
        # Systemd already does that on behalf of knxd, via 'knx.socket'.
        # *** DO NOT use both "-RS" and "-b ip:" (unless you specify a
        # different multicast address on one of them). You'd create a loop.
        # If you have KNX hardware on a serial port or USB, add the appropriate
        # "-b TYPE:…" option. In this case, you probably want to set up a multicast
        # server, not a client (i.e. use "-D -T -R -S", not "-b ip:").
        # DO NOT use both.
        # If your KNX hardware is a KNX/IP gateway that doesn't do multicast,
        # use "-b ipt:192.168.1.2" (or its DNS name) to talk to it.
        # KNX MUST NOT have more than one path between any two devices. Thus,
        # you need to make sure that the KNX/IP gateway does not route multicast
        # before you use both "-S" and "-b ipt:".
        # The default bus address of knxd is 0.0.1. If that's in use in your KNX
        # network (or if you run more than one knxd on your network), set a
        # different address, for example "-e 7.0.99".
        # You should have a block of free addresses on your KNX bus which knxd can
        # assign to clients: "-E 7.0.100:28" will use 7.0.100 through 7.0.127.
        # If no such range is given, or if it's full, knxd uses its own address.
        # That mostly works, but separate addresses are much better.
        # Run `knxd --help` to get a complete list of available options and drivers.
        ## DO NOT use the following options:
        ## -i -- /lib/systemd/system/knxd.socket does this for us
        ## -u /run/knx -- likewise
        ## -d -- /lib/systemd/system/knxd.service expects knxd to run in the foreground
        ## -p PIDFILE -- please use systemctl to control knxd
        # This file is ignored when NOT using systemd: edit /etc/default/knxd instead #
        rd@home:/etc$
        rd@home:/etc/default$ apt-cache policy knxd
        knxd:
        Installed: 0.14.23-1
        Candidate: 0.14.23-1
        Version table:
        *** 0.14.23-1 100
        100 /var/lib/dpkg/status
