knxd docker
    knxd docker
    Hi everyone.
    I am using the docker version of knxd. I was using an old IP interface but I now changed to a Weinzierl 732 IP Interface.
    My question is: although working, are the following start parameters the best?
    docker run -it --name knxd --restart always --net=host welteki/knxd knxd -e 1.1.222 -E 1.1.223:10 -D -T -R -S -i -t 65535 --send-delay=70 -b ipt:192.168.0.20
    My interface supports tunneling (not routing) and the addresses 1.1.222 to 1.1.233 are free.
    Do I still need the delay and all the other parameters?
    Also... there are quite a few knxd dockers available. Which one do you use?
    Thanks.
    Regards,
    Mike
    Your interface supports 8 parallel (secure) tunneling connection. I'm curious: what you are using knxd for in this setup?
      I also thought that I wouldn't need knxd after the interface change.
      For Home Assistant and other connections I do not need knxd. But I still seem to need for Gira Home Server and for my homebridge (Google Home link with knx).
        No idea about homebridge, but afaik Gira Home Server can use a tunnel connection (maybe only secure, not sure - but knxd doesn't support secure)
          The picture shows how I have GHS configured. If I replace the multicast address for the IP interface address... it does not work. I guess GHS needs a IP router?
            Well, you probably will need to select something else than "Knx/ip routing" to not use routing 🤷
              It seems like the only logic option:
                Afaik it tunneling was added recently (maybe a year or two) - are you running latest software? Not really sure though as I never used a Gira HS myself (and its quite offtopic, but its your thread anyway 🤣)
