ist zwar kein Problem von knxd aber eventuell kann mir trotzdem jemand helfen.
Versuche den Main Branch auf RockyLinux zu kompilieren.
Erhalte bei configure einen Fehler das libev nicht gefunden wurde.
Libev ist aber vorhanden:
./configure --disable-systemd --enable-busmonitor --enable-eibnetipserver --enable-eibnetip --enable-eib netserver --enable-eibnetiptunnel --enable-groupcache --disable-usb
checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for a thread-safe mkdir -p... /usr/bin/mkdir -p checking for gawk... gawk checking whether make sets $(MAKE)... yes checking whether make supports nested variables... yes checking build system type... x86_64-pc-linux-gnu checking host system type... x86_64-pc-linux-gnu checking how to print strings... printf checking whether make supports the include directive... yes (GNU style) checking for gcc... gcc checking whether the C compiler works... yes checking for C compiler default output file name... a.out checking for suffix of executables... checking whether we are cross compiling... no checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking whether gcc understands -c and -o together... yes checking dependency style of gcc... gcc3 checking for a sed that does not truncate output... /usr/bin/sed checking for grep that handles long lines and -e... /usr/bin/grep checking for egrep... /usr/bin/grep -E checking for fgrep... /usr/bin/grep -F checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B checking the name lister (/usr/bin/nm -B) interface... BSD nm checking whether ln -s works... yes checking the maximum length of command line arguments... 1572864 checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop checking for /usr/bin/ld option to reload object files... -r checking for objdump... objdump checking how to recognize dependent libraries... pass_all checking for dlltool... no checking how to associate runtime and link libraries... printf %s\n checking for ar... ar checking for archiver @FILE support... @ checking for strip... strip checking for ranlib... ranlib checking command to parse /usr/bin/nm -B output from gcc object... ok checking for sysroot... no checking for a working dd... /usr/bin/dd checking how to truncate binary pipes... /usr/bin/dd bs=4096 count=1 checking for mt... no checking if : is a manifest tool... no checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking for dlfcn.h... yes checking for objdir... .libs checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC -DPIC checking if gcc PIC flag -fPIC -DPIC works... yes checking if gcc static flag -static works... no checking if gcc supports -c -o file.o... yes checking if gcc supports -c -o file.o... (cached) yes checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes checking for gcc... (cached) gcc checking whether we are using the GNU C compiler... (cached) yes checking whether gcc accepts -g... (cached) yes checking for gcc option to accept ISO C89... (cached) none needed checking whether gcc understands -c and -o together... (cached) yes checking dependency style of gcc... (cached) gcc3 checking for g++... g++ checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking dependency style of g++... gcc3 checking how to run the C++ preprocessor... g++ -E checking for ld used by g++... /usr/bin/ld -m elf_x86_64 checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking for g++ option to produce PIC... -fPIC -DPIC checking if g++ PIC flag -fPIC -DPIC works... yes checking if g++ static flag -static works... no checking if g++ supports -c -o file.o... yes checking if g++ supports -c -o file.o... (cached) yes checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes checking dynamic linker characteristics... (cached) GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking for bison... bison -y checking for flex... flex checking lex output file root... lex.yy checking lex library... none needed checking whether yytext is a pointer... no checking dependency style of gcc... gcc3 checking sys/time.h usability... yes checking sys/time.h presence... yes checking for sys/time.h... yes checking sys/select.h usability... yes checking sys/select.h presence... yes checking for sys/select.h... yes checking whether g++ supports C++11 features by default... yes checking build system compiler gcc... yes checking for build system preprocessor... gcc -E checking for build system executable suffix... checking for compiler option -std=c++0x... yes checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking argp.h usability... yes checking argp.h presence... yes checking for argp.h... yes checking for library containing argp_parse... none required checking for linux/rtnetlink.h... yes checking for linux/usbdevice_fs.h... yes checking for iphlpapi.h... no checking whether SA_SIZE is declared... no checking whether __FreeBSD__ is declared... no checking whether __APPLE__ is declared... no checking for gethostbyname_r... yes EMI because of ft12 using CC=gcc using CXX=g++ + test -d libfmt + cd libfmt + git fetch + git checkout 4.x Already on '4.x' Your branch is up to date with 'origin/4.x'. + git merge origin/4.x Already up to date. + cmake . -- CMake version: 3.26.5 -- Version: 4.1.1 -- Build type: Release -- Target 'doc' disabled (requires doxygen) -- Configuring done (0.0s) -- Generating done (0.0s) -- Build files have been written to: /root/knxd/libfmt + make fmt [100%] Built target fmt checking fmt/printf.h usability... yes checking fmt/printf.h presence... yes checking for fmt/printf.h... yes checking for ev_run in -lev... no configure: error: libev not found
[root@Edomi knxd]# dnf install libev Letzte Prüfung auf abgelaufene Metadaten: vor 1:48:44 am Sa 17 Feb 2024 08:57:34 CET. Das Paket libev-4.24-6.el8.x86_64 ist bereits installiert. Abhängigkeiten sind aufgelöst. Nichts zu tun. Fertig. [root@Edomi knxd]#
