nach dem Update von Debian 12 (knxd 0.14.54) auf Debian 13 (knxd 0.14.73) läuft bei mir knxd nicht mehr so stalbil wie vorher:
knxtool groupswrite bekommt nach gut 2 Tagen Laufzeit ein Connect failed: Connection reset by peer:
Bin für jeden Hinweis dankbar, der zum Debuggen des Problems beiträgt :-).
sh@home:~$ knxtool groupswrite ip:127.0.0.1 1/5/0 1
sh@home:~$ su -
Password:
root@home:~# systemctl status knxd
● knxd.service - KNX Daemon
Loaded: loaded (/usr/lib/systemd/system/knxd.service; enabled; preset: enabled)
Active: active (running) since Mon 2025-10-27 17:57:25 CET; 2 days ago
Invocation: 157518d518b54ea0ae1cd9a78bb415be
TriggeredBy: ● knxd.socket
● knxd-net.socket
Main PID: 1780 (knxd)
Tasks: 1 (limit: 4713)
Memory: 1.9M (peak: 3.4M, swap: 0B, swap peak: 4K)
CPU: 2min 55.794s
CGroup: /system.slice/knxd.service
└─1780 /usr/bin/knxd -e 15.15.241 -E 4.0.1:8 -u /tmp/eib -B single --send-delay=70 -b ipt:mdt
Oct 27 17:57:24 home systemd[1]: Starting knxd.service - KNX Daemon...
Oct 27 17:57:25 home systemd[1]: Started knxd.service - KNX Daemon.
root@home:~# journalctl -b |grep knxd
Oct 27 17:52:11 home systemd[1]: /usr/lib/systemd/system/knxd-net.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knxnet → /run/knxnet; please update the unit file accordingly.
Oct 27 17:52:11 home systemd[1]: /usr/lib/systemd/system/knxd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knx → /run/knx; please update the unit file accordingly.
Oct 27 17:52:23 home systemd[1]: Starting knxd-net.socket - KNXnet/IP socket...
Oct 27 17:52:23 home systemd[1]: Listening on knxd.socket - KNX Daemon (socket).
Oct 27 17:52:23 home systemd[1]: Listening on knxd-net.socket - KNXnet/IP socket.
Oct 27 20:50:58 home systemd[1]: /usr/lib/systemd/system/knxd-net.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knxnet → /run/knxnet; please update the unit file accordingly.
Oct 27 20:50:58 home systemd[1]: /usr/lib/systemd/system/knxd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knx → /run/knx; please update the unit file accordingly.
Oct 27 20:51:04 home systemd[1]: /usr/lib/systemd/system/knxd-net.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knxnet → /run/knxnet; please update the unit file accordingly.
Oct 27 20:51:04 home systemd[1]: /usr/lib/systemd/system/knxd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knx → /run/knx; please update the unit file accordingly.
Oct 27 20:51:11 home systemd[1]: /usr/lib/systemd/system/knxd-net.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knxnet → /run/knxnet; please update the unit file accordingly.
Oct 27 20:51:11 home systemd[1]: /usr/lib/systemd/system/knxd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knx → /run/knx; please update the unit file accordingly.
Oct 28 10:51:17 home systemd[1]: /usr/lib/systemd/system/knxd-net.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knxnet → /run/knxnet; please update the unit file accordingly.
Oct 28 10:51:17 home systemd[1]: /usr/lib/systemd/system/knxd.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/knx → /run/knx; please update the unit file accordingly.
root@home:~# systemctl restart knxd
root@home:~#
logout
Send request
sh@home:~$ knxtool groupswrite ip:127.0.0.1 1/5/0 0
Send request
sh@home:~$
