Mixing KNX actors with Konnekting sensors
    I'm thinking about switching out my current home automation system with a Konnekting based one.
    For my main fuse box I'd prefer using actual company products rather than own build. The MDT AKK-0816.03 module looks perfect for my use (6x).
    Since Konnekting is compatible with KNX I expect that Konnecting based sensors/switches should be able to control these actors.
    However, I'm wondering how to program the MDT modules. Do I need ETS for this or is there another way? I'd like to avoid having to buy an ETS license just to set up the addresses in the actors. For the switches I would then use the Konnekting suite.
    Kurt
    Hi Kurt,
    for MDT and other "not Konnekting" Devices you need ETS... there is no other way :/ But you can use ETS Lite.
    And yes, Konnekting Sensors/Devices can control "official" KNX Devices.
    BG
    Eugen
      in my tests I used MDT actor + sensor together with Konnekting => works great.
