Arduino + 5WG1 117-8AA12 + connect external power supply
    Hello,
    I have done a test to connect a arduino pro mini to a 5WG1 117-8AA12 to the knx bus and i have a working test solution with a few push buttons.
    The Arduino is getting power from the 5WG1 117-8AA12 but if i want to use a bigger version of adruino the power of the BCU will not be strong enough so i want to use a external power supply to power the arduino.
    I have read that it is not allowed to connect the GND from the BCU (5WG1 117-8AA12) to the GND of a external Power supply for the Arduino.
    Is there anyone who have a schematic with optocouplers of a working setup ?
    My electronic knowledge is a little bit far away.
    Thanks
    Didier
    you need ADUM1201 only between Arduino and BCU
      To be more precise: Use this IC http://www.analog.com/media/en/techn...M1200_1201.pdf to do galvanic isolation between BCU and your arduino. Then you can safely power your arduino with an external power supply without interfering with KNX.
        Eugenius and Tuxedo ,
        Thanks for the info.
        I have ordered the ADUM1201 will try next weekend i hope.
        Best regards
        Didier
