KonnektING library
    Zitat von Eugenius Beitrag anzeigen
    First problem that I see: you defined not enough "virtual EEPROM"...
    byte virtualEEPROM[16];
    this was only for communication sketch demonstration... you need at least 180 bytes...
    It's always a good idea to allocate approriate space for EEPROM. Makes no sense to just allocate 16 bytes, as the EEPROM is anyhow organized in pages that are bigger than 16 bytes. .
    So just use 1k or 2k as default. SAMD has enough of it and 1k or 2k is far away from beeing "too much".
      virtualEEPROM is only for communication sketch, that also works on 32u4 and 328p. So, it is not a good idea to allocate 1k or more
