knx.read and knxEvents
    Hi, it's me again...
    I'm looking to generate an action when I send an "on-off" via the bus. But nothing appen. The only example I found it's the "UFI_KNX_communication_test.ino"
    but I'm not able to get the information and the next step it's to retrieve the value send on 1byte like percentage.
    Can you kindly help me?
    BR,
    Ivan
    "incoming" group telegrams receive via
    void knxEvents(byte index) {
    Then you need to check the com-object with the given given for changes / it's new value.
    Outgoing KNX events are sent through changes on a comm-object, like
    Knx.write(comObjId, value);
    Both works only, if the com-object has been assigned with an group-adress through the suite.
      void knxEvents(byte KNX_Obj) { //KNX_Obj = Suite ComObj_Nummer+1)
         if (KNX_Obj == 1){
              percentage1 = (byte)Knx.read(1);
         if (KNX_Obj == 2){
              percentage2 = (byte)Knx.read(2);
      Zuletzt geändert von Eugenius; 29.08.2016, 16:13.
        I understand what you mean but with the code above I cannot turn on a simple light!
        And the BckLightPin variable is working because I can use it when I setup the program and there I can turn on and off changing in the Suite (it Rocks!!!)
        Something like that?
            // nothing to do in this sketch
            bool BckLight = (bool)Tools.getUINT8Param(2);  //
            byte BckLightPin = (byte)Tools.getUINT8Param(3);
            bool BckLightExt = (bool)Tools.getUINT8Param(4);
            #ifdef DEBUG
                DEBUG.println(BckLight);
                DEBUG.println(BckLightPin);
                DEBUG.println(BckLightExt);
                DEBUG.println(index);
            #endif
            switch (index){
            case 2 : // object index 1 has been updaed
              if (Knx.read(2)) {
                      digitalWrite(BckLightPin, HIGH);
                      #ifdef DEBUG
                                DEBUG.println("Toggle LED: on");
                      #endif
                    else {
                      digitalWrite(BckLightPin, LOW);
                      #ifdef DEBUG
                                DEBUG.println("Toggle LED: off");
                      #endif
              break;
              default:
              break;
          this only for setup function (one time on device start):
              #ifdef DEBUG
              #endif
          knxEvents function:
              switch (index){
              case 2 : // object index 2 has been updated
                if (Knx.read(2)) {
                        #ifdef DEBUG
                        #endif
                      else {
                        #ifdef DEBUG
                        #endif
                break;
                default:
                break;
            Maybe it's wise to give a reason for that:
            knxEvents() is - the name already explains it - an event method. It is triggered directly after a mathcing telegram has received. The execution of this method has to be as short as possible, otherwise it may block reading further telegrams. Reading on every event the parameters from eeprom eats unnecessary cpu cycles. So it's a good idea to read-in parameters in setup() and keep them in memory for fast access.
              I understand, thanks for your advice.
              it wont do what I want and I cannot fast debug (hardware issues) and now I have to wait to resolve that before continue with the software part.
              I put the project if you want to have a look.
                i see the first error in your sketch:
                you will receive a value to turn on or off a backlight. you have to define it as an input object:
                KnxComObject KnxDevice::_comObjectsList[] = {
                /* don't change this */ Tools.createProgComObject(),
                // Currently, Sketch Index and Suite Index differ for ComObjects :-(
                /* Sketch-Index 1, Suite-Index 0 : */ KnxComObject(KNX_DPT_16_001, COM_OBJ_SENSOR), //code
                /* Sketch-Index 2, Suite-Index 1 : */ KnxComObject(KNX_DPT_1_001, [B]COM_OBJ_LOGIC_IN[/B]), //light
                /* Sketch-Index 3, Suite-Index 2 : */ KnxComObject(KNX_DPT_1_001, COM_OBJ_SENSOR), //relay
                here you can find discription for it (C/R/W/T/U/I indicators like in ETS):
                https://github.com/KONNEKTING/Konnek...omObject.h#L58
                Zuletzt geändert von Eugenius; 30.08.2016, 14:58.
