so hier der output: PA ist nun wieder 15.15.255 sollte aber 1.1.2 sein lt. ETS
--- Available filters and text transformations: colorize, debug, default, direct, esp32_exception_decoder, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Miniterm on COM5 115200,8,N,1 ---
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
ip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd _drv:0x00,wp_d*wm:[1] AutoConnect
*wm:[2] ESP32 event handler enabled
*wm:[2] Connecting as wifi client...
*wm:[2] setSTAConfig static ip not set, skipping
*wm:[1] Connecting to SAVED AP: xx
*wm:[1] connectTimeout not set, ESP waitForConnectResult...
*wm:[2] Connection result: WL_CONNECTED
*wm:[1] AutoConnect: SUCCESS
*wm:[2] Connected in 2826 ms
*wm:[1] STA IP Address: 192.168.3.56
readMemory
RESTORED 00 FA 00 00 00 00 00 00 00 03 11 02 00 01 04 00 01 60 00 01 00 00 00 00 00 00 00 01 00 00 00 01 04 00 00 00 00 00 00 00 00 00 01 E0 00 17 0C 00 01 10 00 1E 54 65 6D 70 65 72 61 74 75 72 73 65 6E 73 6F 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FA AB CD 78 01 00 00 00 08 00 00 00 98 00 08 01 00 00 00 02 00 00 00 AC 00 04 01 00 00 00 02 00 00 00 B0 00 04 01 00 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF
FF FF FF FF FF FF FF FF FF FF FF FF FF 02
DataObject api changed, any data stored in flash is invalid.
expexted DataObject api version: 1, stored api version: FA
ETS has to reprogram PA and application!
setup multicast addr: 224.0.23.12 port: 3671 ip: 192.168.3.56
result 1
progmode on
Basic restart requested
save saveRestores 3
save tableobjs 4
restart
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd _drv:0x00,wp_drv:0x00
mode
IO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1044
load:0x40078000,len:10124
load:0x40080400,len:5828
entry 0x400806a8
*wm:[1] AutoConnect
*wm:[2] Connected in 2875 ms
readMemory
result 1
ip: 0, SPIWP:0xee
readMemory
result 1
progmode on
save saveRestores 3
save tableobjs 4
restart
mode
IO, clock div:2load:0x3fff0018,len:4
entry 0x400806a8
*wm:[1] AutoConnect
readMemory
result 1
