Sehr gut
Dann freue ich mich auf den Screenshot. Da kann man sicher noch was abkupfern
./upgrade/?config=haegar80
ERROR: config-file is not writeable by webserver-process; please chmod/chown config-file '/var/www/visu_svn/config/visu_config.xml' ('../config/visu_config.xml').
> chmod a+rw /var/www/visu_svn/config/visu_config.xml
> chmod a+rw /var/www/visu_svn/config/backup
> chmod a+rw /var/www/visu_svn/config/visu_config_previewtemp.xml
