Events within a time frame
    Is there a way to act only when 2 events happen within a x minute time frame?
    Eg. if door is open and alarm is switched off within 45 seconds, this means that the person has come home.
    If I don't use this time frame, I think that the controller will also think "enter home" when the following happens:
    - person wakes up and switches alarm off when going to kitchen
    - person opens the door to catch the newspaper
    Tx for your suggestions
    Ivan
    Assume "door", "alarm" and "info" are your groupaddresses:
    As simple solution would be:
    if after(door==ON,45000u64) and "alarm"==OFF then write("info",$I'm here$c14) endif
    you can be more sophisticated, eg. watch, if the door is still open or is closed and so on.
    Enertex Produkte kaufen
