Can not use new EIBstudio because CRLF variable is already predefined
    I wanted to upgrade my EIBstudio from 3.015 to latest version 3.203 but I get an error saying that a variable CRLF can not be re-defined again.
    In my program I use the CRLF variable in pieces of the program that I copied from somebody else and that I modified to send TCP commands.
    Some of these pieces of code are the following:
    CRLF = $$
    GET_1 = $$
    GET_2 = $$
    GET_3 = $$
    GET_4 = $$
    GET_5 = $$
    String = $$
    TCP_ConnectionState = 6u08
    gudeSendDelay = 500u64
    gudePort = 80u16
    gudeIP = 192.168.1.40
    //gudeInit=0b01
    gudeCommandSent=0b01
    gudeToggle=0b01
    gudeTrigger=0b01
    gudeOFF=$GET /?Allesuitzetten HTTP/1.1$
    gudeCommand = $$
    // TCP message
    if gudeTrigger then \\
    stringset(CRLF, 0x0A0Du16, 0u16); \\
    GET_1 = gudeCommand + CRLF; \\
    GET_2 = $User-Agent: Wget/ 1.0.10$ + CRLF; \\
    GET_3 = $Accept: */*$ + CRLF; \\
    GET_4 = $Host: 192.168.1.40$ + CRLF; \\
    GET_5 = $Connection: Keep-Alive$ + CRLF + CRLF; \\
    String = GET_1 + GET_2 + GET_3 + GET_4 + GET_5 \\
    endif
    It turns out that in the new EIBstudio version, there is also a CRLF variable that is predefined. The definition has the value "tostring(0xd,0xa)
    Since my original code defines a CRLF value which is already predefined, I now get the error:
    " >CRLF = $$< in file "C:/Users/Perry/Documents/KNX/Enertex producten/EibStudio-win V3.203/EibStudio-win/EibstudioData/tmpApp.txt"
    Predefined variable cannot be re-defined in >CRLF=$$<
    EibParser ended with an error"
    I tried replacing all instances of CRLF with CRFX to see if I could just use a different variable, but then the TCP/http commands from the EIBPC no longer work.
    Now I am not sure how to solve this. I went back to using the old EIBstudio version and its code and everything works as before. However, I would like to upgrade to latest version.
    Any tips on what I can do to get it working?
    Thanks in advance,
    Perry
    CRLF is now as predefined Constant. Just delete
    CRLF = $$
    in your code above.
    Enertex Produkte kaufen
      Thank you, it works fine now.
