Visu - macro - error code 44
    I have added another button in my visu using the assistant. After saving and importing into EIBPC and ' compile program' I get the following error:
    !! User Error !!
    Macro is not defined: "UmschaltShifter( Licht1ID,ErdgeschossWoonkamerID,"banklicht-2/0/0","Status banklicht-2/0/30",LIGHT)"
    EC:44
    EibParser ended with an error
    It​ was working before without issues . The error points to a GA that was not changed in the Visu and which worked before.
    I can not find the error code 44 in the manual.
    Does anybody have an idea what it means?
    Ps: the error message appears immediately after successful importing of group addresses, i.e. '.import of group addresses.... tmpAddr.txt has been written' is the first line, immediately followed by the error code shown above
    Zuletzt geändert von Perry; 21.06.2017, 12:49.
    Err44 is "Macro is not defined". I gues the Libs are missing.
    Enertex Produkte kaufen
      That would be strange, because it was working before without any issues.
      I only started the Visu assistant and added a button (and dragged the associated GA to it).
      Then I chose 'import into EIBPC'. I received a warning message that told me to make sure that the 'makrobibliotheken' "EnertexWebV3.lib" was added in the program.
      I have already have the following libraries in the Macro Library of my EIBstudio program:
      [MacroLibs]
      ​​​​​​​//Macro Library
      EnertexWebENGV3.lib
      EnertexENGV3.lib
      EnertexSceneENG.lib
      I assume these are OK since they have been working fine before (I guess the ENG part just means it is in the English language?).
        You are right. ENG means English, but I think the Assistent needs the German Version to be added, too.
          Ok, so I can add and mix these libraries up in EIBSTUDIO?
          Do I need a specific version of the German libraries?
            Ok, so I took the plunge and downloaded the latest Libraries ( in German) and included the EnertexWebV3.lib in EIBSTUDIO.
            EIBstudio then complained that something was not uniquely identified. I guessed that this was because of the 'old' English library, so I took that out and then it worked.
            Unfortunately, the language inside the web pages is now always German. Would it be possible to have it in English and still keep using the Visual Assistant?
              Yes, you can simply modify the Makrolibs and the visu code for your needs with the editor.
