[EibPC] CommandFusion button and slider controls synchronization
    Dear group,
    Using the last CommandFusion macros, I'm currently successfully using the JoinMinMax macro to have a iViewer slider write the desired scaled value to a 8bits lighting actuator.
    However, how is it possible to synchronize the state of the slider in order to reflect changes occured on the KNX side ? Do I have to use another macro where the actuator status could be set?
    Thanks for any answer,
    Alexandre Liduena.
    Dear Alexandre,
    with each changes on the KNX side the status of the sliders should update automaticly.
    If that does not work, send your program with esf-file and gui-project to eibpc@enertex.de
    steffi
    Enertex Bayern GmbH - www.eibpc.com
