I'm running eibpc and I would like to make a link to commandfusion.
You can find the Macros as described in https://knx-user-forum.de/eibpc/1037...h-english.html
After unzipping you can find a directory "examples". There you can find for any possible connection an example. Just click through.
It should not be too difficult. Basically you give each widget an ID in the guiDesigner, called Joins, and you can connect these Joins to a variable of your program or a group address direclty with one of the macros.
For me, the main task is to get a nice GUI. I'm not too talented in these things, but you can see Michel38's examples, how it could be.
For the iPhone there is a complete GUI in the examples dir, which is made by him.
Just ask, if you have more specific question.
Did you enter the IP of your EibPC into the GuiDesigner ProjectProperties?
You can also set the Variable ipad_Debug to ON (in your case) with the debugger. You can watch the online monitor at groupadress 1/2/3 for some debugging information. But my guess is also the IP in the Project Properties.
Thx for all the responses. I already set the IP of my EibPC into the Project Properties.
Your output "NM:d10=1" means, the Makro has built a queue, and finds the next message (NM) comming from the iPad with d10=1. But this output happens only, when the connection is not yet established, as the e.g. password is not correct. Otherwise you would find a "OM:d10=1"
In your debug code you should find a "Pass ok" coming at '1/2/3'c14. Look there, once you're opening CF on your iPad. I guess you will find a "NoP" instead. I donnot remember how to set the password in CF from here. I'll have to look, or Uwe, do you know?
It seems like CF is sending the password, then looses connection and so the connection-establishment fails.
I know that CF had a view TCP/IP bugs in version 3.x
You could try latest iViewer Next. Maybe that solves your problem.
You could also enable debugging in the iViewer settings and have a look on the "Mixed Log"
Use GoogleChrome to check out the debug mode.
The iViewer tells you where to connect on startup if you enabled "Remote Debugging".
Otherwise you could use WireShark to scan for the packages.
Please make the whole sequence again. Your System is already connected, as you see the "OM:" output. But CF tries to re-login to the EibPC and doesnot answer.
So close CF (do realy close it!) and wait for 1 minute until no message on 1/2/3 is reported. Then open CF and please show again the messages here.
