HTML eMail
    HTML eMail
    ich gebe die Druckwerte der Heizung aus.
    Der Rohtext lautet:
    <html><head><meta name="qrichtext" content="1" /></head><body style="font-size:11pt;fontfamily:Sans Serif"><span style="font-weight:600"></span>Druck Solekreislauf<br><table><tr><td>Datum</td><td>Minimum</td><td>Maximum</td></tr><tr><td>01.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.84</td></tr><tr><td>01.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>02.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>02.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>03.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.84</td></tr><tr><td>03.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>04.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>04.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>05.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>05.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>06.06.2022</td><td>&nbsp-0.08</td><td>&nbsp86507.52</td></tr><tr><td>06.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>06.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>06.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.84</td></tr><tr><td>07.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>07.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>08.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.84</td></tr><tr><td>08.06.2022</td><td>&nbsp1.68</td><td>&nbsp1.68</td></tr><tr><td>09.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>09.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>10.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.68</td></tr><tr><td>11.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>11.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>11.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>12.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>12.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.76</td></tr><tr><td>12.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.60</td></tr><tr><td>12.06.2022</td><td>&nbsp1.60</td><td>&nbsp1.60</td></tr><tr><td>13.06.2022</td><td>&nbsp1.52</td><td>&nbsp1.68</td></tr></table></body></html>
    heraus kommt die Mail, bei der nur die WErte bis 9.6. drinstehen.
    Wenn ich das Ding aber in eine HTML-Datei Kopie siehts auch gut aus.
    Any Idea?
    Die länge ist 65500 Zeichen.
    Der Code:
    if MailSend == 1b01 or htime(23,59,59) then {
    SoleChart = SoleChart + $<tr><td>$ + split(DATE_STRING,0u16,10u16) + $</td>$;
    SekundChart = SekundChart+ $<tr><td>$ + split(DATE_STRING,0u16,10u16) + $</td>$;
    SoleChart = SoleChart + $<td>&nbsp$ + convert(SoleMin,$$) + $</td><td>&nbsp$ + convert(SoleMax,$$) + $</td></tr>$;
    SekundChart = SekundChart+ $<td>&nbsp$ + convert(SekundMin,$$) + $</td><td>&nbsp$ + convert(SekundMax,$$) + $</td></tr>$;
    MailBodySole = MailBodyFormatLine + $Druck Solekreislauf<br><table>$ + TableHeader + SoleChart + $</table>$;
    MailBodySole = MailBodySole + MailBodyFormatEnd;
    sendhtmlmail(MailTo,MailSubject,MailBodySole);
    MailBodyPrim = MailBodyFormatLine + $Druck Sekundaerkreislauf<br><table>$ + TableHeader + SekundChart + $</table>$;
    MailBodyPrim = MailBodyPrim + MailBodyFormatEnd;
    sendhtmlmail(MailTo,MailSubject2,MailBodyPrim);
    MailSend = 0b01;
    } endif;
    Vermutlich irgendein Längenproblem, wobei ich die Variablenlänge mit 65500 Zeichen bereits definiert habe.
    MAilausgabe:
    Druck Solekreislauf
    Datum Minimum Maximum
    01.06.2022 1.60 1.84
    01.06.2022 1.68 1.68
    02.06.2022 1.60 1.76
    02.06.2022 1.68 1.68
    03.06.2022 1.60 1.84
    03.06.2022 1.68 1.68
    04.06.2022 1.60 1.76
    04.06.2022 1.68 1.68
    05.06.2022 1.60 1.76
    05.06.2022 1.68 1.68
    06.06.2022 -0.08 86507.52
    06.06.2022 1.68 1.68
    06.06.2022 1.60 1.84
    07.06.2022 1.60 1.76
    07.06.2022 1.68 1.68
    08.06.2022 1.60 1.84
    08.06.2022 1.68 1.68
    09.06
    Enertex EibPC
    Ich komme nicht drauf.
    Gruß Peter
    für Mail gilt doch eine kürzere Maximal-Länge, wenn ich mich nicht täusche.
    Handbuch sagt:
    Alle Zeichenketten werden auf 1400 Zeichen begrenzt
      naja, aber das macht bei HTML ja kaum sinn, denn das sind dann ja relativ lange Zeichenketten.
      Wie bekommt man denn derartige Werte monatsweise ausgelesen und "rüber" per Mail?
        ja, Sinn ist ne gute Frage. Wurde glaub ich auch schon mehrfach gefordert, dass zu erhöhen, aber ich hab gard noch mal durchgezählt, bis zum 09.06. sind es genau die 1400 Zeichen.
          wow, also doch Längenproblem und dann vermutlich im Skript HTMLMAIL, denn meine lange Zeichenkette geht ja.
          Aber der Kern des Problem ist noch da, wie bekomme ich die Werte rüber? any Idea ?
          Sag nicht alle 10 Tage ne Mail ;-)....
          gibt es eine Möglichkeit z.b. eine Textfile anzuhängen und dann zu versenden?
            besser täglich per FTP in eine Datenbank schreiben (z.B. auf NAS oder Fritzbox)
              ... gibt es da irgendwo einen Beispielcode?
                Im Handbuch von EibStudio, bei der Version 4.1xx ab Seite 54. In der älteren Version einfach nach dem Kapitel "FTP Datenströme" suchen.
                Enertex Produkte kaufen
