Your personal epc code is stored within the program folder. If you replace the EibStudio program folder without storing your personal epc code at another place first, your data will be lost.
The reason for not seeing the esf data is probably the missing structure within your epc code. You need to have the basic structure described in the booklet, e.g.:
