Windows 8 problem
    [EibStudio] Windows 8 problem
    Hello,
    Does someone have problems with eibstudio and windows8?
    I can monitor eib messages, but nconf remains blocked in transferring project or patches.
    No firewall, no antivirus.
    Windows 8 64bit.
    Nconf simply hangs and i must reboot the pc.
    With windows 7, i have no problems.
    did you check the build in firewall of win8?
    nconf must have a own rule.
      The firewall is off. No antivirus. UAC is off.
      By pressing the "i" button, eibstudio returns the info of the eibpc.
      Only nconf seems to have problems.
      If i run it from the command line, it hangs too.
        Anyway I would suggest to grant access to nconf within the Win8 FW config. I recognize the same issue each time I use a new EIBStudio and within a new nconf and my the FW isn't active. AFAIK you cannot fully deactivate the FW since Win Vista.
        Cheers,
        Oliver
          Actually pressing the i button is the same as nconf -i [IP address]. The only difference might be that by pressing the i button the nconf is spawned as a child process with the rights of EibStudio whilst using the command line it is running with the current user rights.
          I would suggest to add the nconf in your EibStudioData directory to the allowed programs whitin the firewall.
          There might be however further drawbacks in Windows 8.
          Until there is a better solution just use windows 7 on 32 bit and you will be fine.
          Regards,
          Bernd
            Ok, it worked.
            Very crappy firewall.
            Thanks to everybody.
