EIBStudio hangs - access right message
    [EibStudio] EIBStudio hangs - access right message
    Hello,
    I have on a regular basis the following message after EIB Studio is hanging.
    I am now using v3_012, was using v3_004 and I have the same problem on two different workstations, with 2 different versions on Win7 installed.
    To make it work again I have to copy the whole \eibstudiodata directory and rename the old one. Then it works.
    Have you ever come across this issue ?
    Regards
    Open the task manager and kill nconf.exe. That's the process blocking Eibstudio...
