Retriggering variable change of a variable with same value
    [Codebeispiel] Retriggering variable change of a variable with same value
    Hallo Zusammen.
    What's going on in the following sample, if i set a variable more times with the same value?
    1) Every time i push a KNX button, the "a" variable is set to EIN (the variable "a" is never reset to AUS)
    2) if a==EIN then ...do "HelloWorld".
    Does "HelloWorld" run every time i push the KNX button ?
    Danke für die Erklärung.
    Massimo
    No, only if a will change.
    Enertex Produkte kaufen
      try...
      [highlight=epc]
      if a==EIN then b=$Hello World$; a=AUS endif
      [/highlight]
      Gruß Martin
        Thank you all.
        Brick, i cannot do this because i have later in my code:
        if delay(a, 5 minutes) and a==EIN then do "test"
        I cannot reset a == AUS immediately, otherwise after 5 minutes the "test" function will note be executed.
        Thank you anyway
          and if you try:
          if delay(a, 5 minutes) and a==EIN then b="test"; a=AUS endif ?
            Already done. :-)
            Thanks
              Does event() work with variables or only GA? If yes I would do it with event()
                The "change()" function works with variable too, not the "event()"
