Enertex power Supply 960 and time
    Hello all,
    I just bought and connect few days ago a Enertex Power Supply 960 and the date/time on the screen don't refresh.
    I correctly setup date and time groups address (many other devices got the same time from my meteo station and work properly) and the power supply show the time from the last programmation through ETS and never update.
    My last programmation was today 12h30, and the screen still show me 12:30 22.02.2016
    I just successfully update the firmware to 1.006 but the problem is still here.
    What could be wrong ?
    Nothing is wrong. The time and date on the display show the time when maximum current has been fed to the KNX. It's not a clock but a maximum monitor.
    Enertex Produkte kaufen
      Haaa ! Thanks a lot for your answer ! Perhaps the (eng) datasheet should be more specific
        Do you mean, this should be more clearly expressed:
        "The LCD Display shows in two lines on one hand the actual values of current, voltage, power and on the other hand the maximum value of the current associated with time and date stamp"
          My bad ... Don't see this before ...
