Dimming in webserver
    Can you post an example on how I should define a dimmer in the eibpc webserver? (to dim a light to eg 60%)
    I've just set up my first button so every hint is welcome. My goal is to rewrite the generated html code and to host it on an apache webserver. I will call the cgi script of eibpc with the appropriate parameters as they have been defined in the generated html code.
    Tx for your help - Ivan
    Can somebody post an example on how I should define a dimmer in the eibPC webserver?
    I already have defined the following:
    [WebServer]
    shifter(2)[LIGHT,UP,DOWN]$Living$
    [EibPC]
    if webbutton(2)==1 then \\
    if("Switch_Living-0/1/15"==EIN) then write("Switch_Living-0/1/15",AUS) endif;\\
    if("Switch_Living-0/1/15"==AUS) then write("Switch_Living-0/1/15",EIN) endif;\\
    endif
    Now I would like to add the dimmer and show also the actual value on the webdisplay. Any help is much appreciated.
    Ivan
      You need to have an EIB group for dimming, e.g. "Dimming_Living".
      This group is either of type "dimmobject"=4bit or dimming with absolute value, which is then usually of type 1 byte unsigned.
      Then just write to that group a you do for switching.
      Of course you need a dimmable EIB actor.
      Gruss Pio
        Zitat von pio Beitrag anzeigen
        You need to have an EIB group for dimming, e.g. "Dimming_Living".This group is either of type "dimmobject"=4bit or dimming with absolute value, which is then usually of type 1 byte unsigned.
        MyDimmerValue="GADimmer-1/2/3"
        if webbutton(2)==1 then {
                 if (MyDimmerValue<90%) then write("GADimmer-1/2/3",MyDimmerValue+10%)  endif
        } endif
        if webbutton(2)==3 then {
                 if (MyDimmerValue>10%) then  write("GADimmer-1/2/3",MyDimmerValue-10%)  endif
        } endif
        if webbutton(2)==2 then {
         write("Switch_Living-0/1/15",!"Switch_Living-0/1/15")
        } endif
        Hint: Use {} - it's not yet documented in this release but already works.
        Enertex Produkte kaufen
          Tx for the tip! It's working perfect.
          Last question: can I also write the current dimming value to the web interface (eg 70%)?
          Ivan
            if change(MyDimmerValue) then  webdisplay(2, $Dimmer: $ +convert(convert(MyDimmerValue,0f16)/255.0,$$)+$%$, LIGHT,DISPLAY,GREEN) endif
