Hallo
der Zugriff auf den Bus und die Sitemap funktioniert.
Schalte ich jetzt über die Sitemap das Licht an, geht das Licht an und flackert im Sekundentakt an - aus - an usw.
Hier ein Auszug aus der knx.cfg
Hat zufällig jemand eine Idee.
Gruss Oliver
# KNX gateway IP address # (optional, if serialPort or connection type 'ROUTER' is specified) ip=192.168.220.80 # Local KNX Binding bus address. # Use it, when two or more openHAB Instances are connected to the same KNX bus. # (optional, defaults to 0.0.0) busaddr=0.0.0 # Ignore local KNX Events, prevents internal events coming from # 'openHAB event bus' a second time to be sent back to the 'openHAB event bus'. # Note: To send back events second time is a Bug, but for backward compatibility, the behavior is not changed. # For new installations, its recommend to set "ignorelocalevents=true" # (optional, defaults to false) ignorelocalevents=true # KNX IP connection type. Could be either TUNNEL or ROUTER (optional, defaults to TUNNEL) # Note: If you cannot get the ROUTER mode working (even if it claims it is connected), # use TUNNEL mode instead with setting both the ip of the KNX gateway and the localIp. type=TUNNEL # KNX gateway port (optional, defaults to 3671) # Note: If you use eibd, setting to 6720 #port= # Local endpoint to specify the multicast interface, no port is used (optional) localIp=192.168.220.82
Gruss Oliver
