Hallo ich habe OpenHab auf einem Rasperry 3b mittels openHABian installiert und seit dem Update habe ich keine Verbindung mit dem KNX-Bus mehr.
Meine Einstellungen sind:
.items
Rollershutter FF_Schlafzimmer_Rollo "Rollo [%d%%]" <rollershutter> (FF_Schlafzimmer, Shutters)
Number FF_Schlafzimmer_Heating "Heizung" <heating> (FF_Schlafzimmer, Heating)
Number FF_Schlafzimmer_Temperature "Temperatur[%.1f °C]" <temperature> (FF_Schlafzimmer, Temperature)
.things
Bridge knx:ip:bridge [
ipAddress="192.168.0.40",
portNumber=3671,
localIp="192.168.0.4",
type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
autoReconnectPeriod=1,
localSourceAddr="0.0.0"
Thing device generic [
address="1.2.3",
fetch=true,
pingInterval=300,
readInterval=3600
Type rollershutter : FF_Schlafzimmer_Rollo "Shade" [ upDown="0/0/6+0/0/21", stopMove="0/0/9", position="0/0/28" ]
Type number : FF_Schlafzimmer_Temperatur "Temperatur" [ ga="9.001:<1/2/20" ]
.sitemap
sitemap kolma label="kolma" {
Frame {
Group item=GF
Group item=FF
Group item=F2
Group item=F3
knx.cfg
# KNX gateway IP address
ip=192.168.0.40
# Ignore local KNX Events, prevents internal events coming from
ignorelocalevents=true
# KNX IP connection type. Could be either TUNNEL or ROUTER (optional, defaults to TUNNEL)
type=TUNNEL
# Local endpoint to specify the multicast interface, no port is used (optional)
localIp=192.168.0.4
openhab.log
2018-06-06 22:48:05.398 [ERROR] [NXnet/IP Tunneling 192.168.0.40:3671] - communication failure on connect
java.net.BindException: Cannot assign requested address (Bind failed)
at java.net.PlainDatagramSocketImpl.bind0(Native Method) ~[?:?]
at java.net.AbstractPlainDatagramSocketImpl.bind(Abst ractPlainDatagramSocketImpl.java:93) ~[?:?]
at java.net.DatagramSocket.bind(DatagramSocket.java:3 92) ~[?:?]
at java.net.DatagramSocket.<init>(DatagramSocket.java :242) ~[?:?]
at tuwien.auto.calimero.knxnetip.ClientConnection.con nect(ClientConnection.java:163) ~[?:?]
at tuwien.auto.calimero.knxnetip.KNXnetIPTunnel.<init >(KNXnetIPTunnel.java:159) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.g etConnection(IPClient.java:107) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.c reateKNXNetworkLinkIP(IPClient.java:90) ~[?:?]
at org.openhab.binding.knx.internal.client.IPClient.e stablishConnection(IPClient.java:77) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKN XClient.connect(AbstractKNXClient.java:178) ~[?:?]
at org.openhab.binding.knx.internal.client.AbstractKN XClient.lambda$0(AbstractKNXClient.java:145) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.cal l(Executors.java:511) [?:?]
at java.util.concurrent.FutureTask.runAndReset(Future Task.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.access$301(ScheduledThreadPoolE xecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$S cheduledFutureTask.run(ScheduledThreadPoolExecutor .java:294) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker( ThreadPoolExecutor.java:1149) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run (ThreadPoolExecutor.java:624) [?:?]
at java.lang.Thread.run(Thread.java:748) [?:?]
Ich gehe davon aus das die Einstellungen nicht richtig sind.
Openhab greift auf die Schnittstelle zu, da ich erst das Netzwerkkabel ziehen musste bevor ich mit der ETS5 darauf zugreifen konnte.
Wenn ich in OpenHab ein Schalter betätige wird es im Log angezeigt.
Ich habe mir auch die KNX-Binding Dokumentation durchgelesen und komme nicht auf den Fehler, was läuft da falsch bei mir?
Vielen Dank im Voraus
.items
.things
portNumber=3671,
type="TUNNEL",
readingPause=50,
responseTimeout=10,
readRetriesLimit=3,
address="1.2.3",
fetch=true,
pingInterval=300,
readInterval=3600
.sitemap
Frame {
Group item=GF
Group item=FF
Group item=F2
Group item=F3
knx.cfg
ip=192.168.0.40
type=TUNNEL
localIp=192.168.0.4
openhab.log
