Vielen Dank erstmal, es fängt an zu laufen.
Hier der Auszug aus der Log:
018-08-20 20:10:00.099 [INFO ] [pse.smarthome.model.script.dev.rules] - Neuer Wert Zufallstimer: 49 Sekunden.
2018-08-20 20:10:49.131 [INFO ] [pse.smarthome.model.script.dev.rules] - Schalte Licht GA_Garage_rechts von NULL nach OFF
2018-08-20 20:13:22.229 [ERROR] [lfe.hap.impl.http.impl.BinaryHandler] - Exception in binary handler
java.io.IOException: Die Wartezeit für die Verbindung ist abgelaufen
at sun.nio.ch.FileDispatcherImpl.read0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.read(SocketDispatcher. java:39) [?:?]
at sun.nio.ch.IOUtil.readIntoNativeBuffer(IOUtil.java :223) [?:?]
at sun.nio.ch.IOUtil.read(IOUtil.java:192) [?:?]
at sun.nio.ch.SocketChannelImpl.read(SocketChannelImp l.java:380) [?:?]
at io.netty.buffer.UnpooledUnsafeDirectByteBuf.setByt es(UnpooledUnsafeDirectByteBuf.java:447) [234
rg.openhab.io.homekit:2.3.0]
at io.netty.buffer.AbstractByteBuf.writeBytes(Abstrac tByteBuf.java:880) [234
at io.netty.channel.socket.nio.NioSocketChannel.doRea dBytes(NioSocketChannel.java:242) [234
at io.netty.channel.nio.AbstractNioByteChannel$NioByt eUnsafe.read(AbstractNioByteChannel.java:119) [234
at io.netty.channel.nio.NioEventLoop.processSelectedK ey(NioEventLoop.java:511) [234
at io.netty.channel.nio.NioEventLoop.processSelectedK eysOptimized(NioEventLoop.java:468) [234
at io.netty.channel.nio.NioEventLoop.processSelectedK eys(NioEventLoop.java:382) [234
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop .java:354) [234
at io.netty.util.concurrent.SingleThreadEventExecutor $2.run(SingleThreadEventExecutor.java:112) [234
at io.netty.util.concurrent.DefaultThreadFactory$Defa ultRunnableDecorator.run(DefaultThreadFactory.java :137) [234
at java.lang.Thread.run(Thread.java:748) [?:?]
2018-08-20 20:13:22.239 [ERROR] [.hap.impl.http.impl.AccessoryHandler] - Exception caught in web handler
2018-08-20 20:20:00.050 [INFO ] [pse.smarthome.model.script.dev.rules] - Urlaub ON
2018-08-20 20:20:00.067 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunrise 1534737420000
2018-08-20 20:20:00.082 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunset 1534787940000
2018-08-20 20:20:00.112 [INFO ] [pse.smarthome.model.script.dev.rules] - Nach Sonnenuntergang und vor Sonnenaufgang
2018-08-20 20:20:00.134 [INFO ] [pse.smarthome.model.script.dev.rules] - Neuer Wert Zufallstimer: 138 Sekunden.
2018-08-20 20:22:18.164 [INFO ] [pse.smarthome.model.script.dev.rules] - Schalte Licht EG_Eingang von NULL nach OFF
2018-08-20 20:30:00.046 [INFO ] [pse.smarthome.model.script.dev.rules] - Urlaub ON
2018-08-20 20:30:00.059 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunrise 1534737420000
2018-08-20 20:30:00.071 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunset 1534787940000
2018-08-20 20:30:00.088 [INFO ] [pse.smarthome.model.script.dev.rules] - Nach Sonnenuntergang und vor Sonnenaufgang
2018-08-20 20:30:00.099 [INFO ] [pse.smarthome.model.script.dev.rules] - Neuer Wert Zufallstimer: 225 Sekunden.
2018-08-20 20:33:45.136 [INFO ] [pse.smarthome.model.script.dev.rules] - Schalte Licht EG_Eingang von OFF nach ON
2018-08-20 20:40:00.021 [INFO ] [pse.smarthome.model.script.dev.rules] - Urlaub ON
2018-08-20 20:40:00.035 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunrise 1534737420000
2018-08-20 20:40:00.047 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunset 1534787940000
2018-08-20 20:40:00.075 [INFO ] [pse.smarthome.model.script.dev.rules] - Nach Sonnenuntergang und vor Sonnenaufgang
2018-08-20 20:40:00.085 [INFO ] [pse.smarthome.model.script.dev.rules] - Neuer Wert Zufallstimer: 166 Sekunden.
2018-08-20 20:42:46.114 [INFO ] [pse.smarthome.model.script.dev.rules] - Schalte Licht EG_Vorraum von NULL nach OFF
2018-08-20 20:42:46.134 [WARN ] [lipse.smarthome.core.items.GroupItem] - Command 'OFF' has been ignored for group 'EG_Vorraum' as it is not accepted.
2018-08-20 20:50:00.030 [INFO ] [pse.smarthome.model.script.dev.rules] - Urlaub ON
2018-08-20 20:50:00.043 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunrise 1534737420000
2018-08-20 20:50:00.054 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunset 1534787940000
2018-08-20 20:50:00.069 [INFO ] [pse.smarthome.model.script.dev.rules] - Nach Sonnenuntergang und vor Sonnenaufgang
2018-08-20 20:50:00.080 [INFO ] [pse.smarthome.model.script.dev.rules] - Neuer Wert Zufallstimer: 174 Sekunden.
2018-08-20 20:52:54.127 [INFO ] [pse.smarthome.model.script.dev.rules] - Schalte Licht EG_Stiegenhaus von NULL nach OFF
2018-08-20 21:00:00.025 [INFO ] [pse.smarthome.model.script.dev.rules] - Urlaub ON
2018-08-20 21:00:00.162 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunrise 1534737420000
2018-08-20 21:00:00.175 [INFO ] [pse.smarthome.model.script.dev.rules] - Sunset 1534787940000
2018-08-20 21:00:00.191 [INFO ] [pse.smarthome.model.script.dev.rules] - Nach Sonnenuntergang und vor Sonnenaufgang
2018-08-20 21:00:00.202 [INFO ] [pse.smarthome.model.script.dev.rules] - Neuer Wert Zufallstimer: 117 Sekunden.
2018-08-20 21:01:57.225 [INFO ] [pse.smarthome.model.script.dev.rules] - Schalte Licht EG_Stiegenhaus von OFF nach ON
Das Problem ist allerdings, dass es sich zwar ein-, aber nicht mehr ausschaltet.
Auch das von Null auf Off verstehe ich nicht ganz, ich bin davon ausgegangen, dass ohnehin eine Rückmeldung ob Off vom Bus da ist...
rg.openhab.io.homekit:2.3.0]at io.netty.buffer.AbstractByteBuf.writeBytes(Abstrac tByteBuf.java:880) [234
rg.openhab.io.homekit:2.3.0]at io.netty.channel.socket.nio.NioSocketChannel.doRea dBytes(NioSocketChannel.java:242) [234
rg.openhab.io.homekit:2.3.0]at io.netty.channel.nio.AbstractNioByteChannel$NioByt eUnsafe.read(AbstractNioByteChannel.java:119) [234
rg.openhab.io.homekit:2.3.0]at io.netty.channel.nio.NioEventLoop.processSelectedK ey(NioEventLoop.java:511) [234
rg.openhab.io.homekit:2.3.0]at io.netty.channel.nio.NioEventLoop.processSelectedK eysOptimized(NioEventLoop.java:468) [234
rg.openhab.io.homekit:2.3.0]at io.netty.channel.nio.NioEventLoop.processSelectedK eys(NioEventLoop.java:382) [234
rg.openhab.io.homekit:2.3.0]at io.netty.channel.nio.NioEventLoop.run(NioEventLoop .java:354) [234
rg.openhab.io.homekit:2.3.0]at io.netty.util.concurrent.SingleThreadEventExecutor $2.run(SingleThreadEventExecutor.java:112) [234
rg.openhab.io.homekit:2.3.0]at io.netty.util.concurrent.DefaultThreadFactory$Defa ultRunnableDecorator.run(DefaultThreadFactory.java :137) [234
rg.openhab.io.homekit:2.3.0]at java.lang.Thread.run(Thread.java:748) [?:?]
