ich möchte einen LED-Strip per MQTT an einem Raspi per Openhab steuern.
ich habe folgende Items angelegt:
Außerdem habe ich folgende rule
und dieses Python Script
Der RGB_Wert wird korrekt an den Raspi übertragen , (123 123 123)
Wie muss ich jetzt das Script anpassen, damit die Strips auf den RGB_Wert reagieren und nicht mehr auf die Argumente in der Kommandozeile?
Kenne mich mit Python überhaupt nicht aus...
Yankee
Color WS28xx_Strip "LED Steifen"
Number RGB_rot "Rot [%s]" { mqtt=">[mosquitto:LED1/rot:command:*:default]" }
Number RGB_gruen "Gruen [%s]" { mqtt=">[mosquitto:LED1/gruen:command:*:default]" }
Number RGB_blau { mqtt=">[mosquitto:LED1/blau:command:*:default]" }
String RGB_Wert { mqtt=">[mosquitto:LED1/gesamt:command:*:default]" }
var String RGBvalues
rule "WSxx Change"
when
Item WS28xx_Strip received command
then
if (receivedCommand instanceof HSBType)
val red = ((WS28xx_Strip.state as HSBType).red * 2.55) as Number
val green = ((WS28xx_Strip.state as HSBType).green * 2.55) as Number
val blue = ((WS28xx_Strip.state as HSBType).blue * 2.55) as Number
val red2 = red.intValue
val green2 = green.intValue
val blue2 = blue.intValue
// RGBvalues = red.toString + " " + green.toString + " " + blue.toString + " "
RGBvalues = red2 + " " + green2 + " " + blue2
sendCommand(RGB_Wert, RGBvalues)
logInfo("WS Status", red + "," + green + "," + blue)
RGB_rot.sendCommand(red)
RGB_gruen.sendCommand(green)
RGB_blau.sendCommand(blue)
// executeCommandLine("/usr/bin/python3 /etc/openhab2/scripts/ws28xx.py " + red.toString + " " + green.toString + " " + blue.toString )
else if (receivedCommand == ON){
//logInfo("WS Status", "ON")
else if (receivedCommand == OFF){
end
#!/usr/bin/env python3
# MQTT
import paho.mqtt.client as mqtt
import time, sys, inspect, ast
import RPi.GPIO as GPIO
# Import the WS2801 module.
import Adafruit_WS2801
import Adafruit_GPIO.SPI as SPI
MQTT_SERVER = "192.168.178.78"
MQTT_PATH = "LED1/gesamt"
# Configure the count of pixels:
PIXEL_COUNT = 41
# other settings
SPI_PORT = 0
SPI_DEVICE = 0
pixels = Adafruit_WS2801.WS2801Pixels(PIXEL_COUNT, spi=SPI.SpiDev(SPI_PORT, SPI_DEVICE), gpio=GPIO)
# The callback for when the client receives a CONNACK response from the server.
def on_connect(client, userdata, flags, rc):
print("Connected with result code "+str(rc))
# Subscribing in on_connect() means that if we lose the connection and
# reconnect then subscriptions will be renewed.
client.subscribe(MQTT_PATH)
# The callback for when a PUBLISH message is received from the server.
def on_message(client, userdata, msg):
global RGB_Wert
RGB_Wert = msg.payload #HERE!
# print(msg.topic+" "+str(msg.payload))
# print("Ergebnis")
print(RGB_Wert)
print("Wert angepasst")
# more callbacks, etc
def setRGBColor(pixels, msg):
# cast from string to int
# r, g, b = int(float(r)), int(float(g)), int(float(b))
pixels.set_pixels( Adafruit_WS2801.RGB_to_color( msg.payload ) )
pixels.show()
print("LED leuchten")
print(RGB_Wert)
#if __name__ == "__main__":
# if len(sys.argv) < 4:
# sys.exit(1)
cmdargs = sys.argv[1:]
setRGBColor(pixels, cmdargs[0], cmdargs[1], cmdargs[2])
client = mqtt.Client()
client.on_connect = on_connect
client.on_message = on_message
client.connect(MQTT_SERVER, 1883, 60)
# Blocking call that processes network traffic, dispatches callbacks and
# handles reconnecting.
# Other loop*() functions are available that give a threaded interface and a
# manual interface.
client.loop_forever()
Yankee
