ich erhalte permantent folgende Meldungen von der Runtime.
Hat jemand eine Idee, wie man das Problem lösen kann? Danke!
Trouble while processing utterance java.lang.IllegalStateException: Syllable relation has already been set
at com.sun.speech.freetts.Segmenter.processUtterance( Segmenter.java:56)
at com.sun.speech.freetts.Voice.runProcessor(Voice.ja va:595)
at com.sun.speech.freetts.Voice.processUtterance(Voic e.java:414)
at com.sun.speech.freetts.Voice.speak(Voice.java:289)
at com.sun.speech.freetts.Voice.speak(Voice.java:235)
at org.openhab.io.multimedia.internal.tts.TTSServiceF reeTTS.say(TTSServiceFreeTTS.java:96)
at org.openhab.io.multimedia.actions.Audio.say(Audio. java:203)
at org.openhab.io.multimedia.actions.Audio.say(Audio. java:183)
at sun.reflect.GeneratedMethodAccessor51.invoke(Unkno wn Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInte rpreter.invokeOperation(XbaseInterpreter.java:729)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInte rpreter._featureCallOperation(XbaseInterpreter.jav a:713)
at sun.reflect.GeneratedMethodAccessor37.invoke(Unkno wn Source)
at org.eclipse.xtext.util.PolymorphicDispatcher.invok e(PolymorphicDispatcher.java:291)
at org.openhab.model.script.interpreter.ScriptInterpr eter.internalFeatureCallDispatch(ScriptInterpreter .java:89)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInte rpreter._evaluateAbstractFeatureCall(XbaseInterpre ter.java:658)
at sun.reflect.GeneratedMethodAccessor36.invoke(Unkno wn Source)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInte rpreter.internalEvaluate(XbaseInterpreter.java:218 )
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInte rpreter._evaluateBlockExpression(XbaseInterpreter. java:321)
at sun.reflect.GeneratedMethodAccessor49.invoke(Unkno wn Source)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInte rpreter.evaluate(XbaseInterpreter.java:204)
at org.openhab.model.script.internal.engine.ScriptImp l.execute(ScriptImpl.java:79)
at org.openhab.model.rule.internal.engine.ExecuteRule Job.execute(ExecuteRuleJob.java:75)
at org.quartz.core.JobRunShell.run(JobRunShell.java:2 13)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run (SimpleThreadPool.java:557)
