habe seit heute problem mit dem openhab Designer.
Wenn ich versuche die Sitemap zu starten bekomme ich folgendes Fehler Meldung: Failed to create the part's controls
und im Detail :
java.lang.NullPointerException
at org.eclipse.xtext.EcoreUtil2.getContainerOfType(Ec oreUtil2.java:100)
at org.eclipse.xtext.GrammarUtil.containingAssignment (GrammarUtil.java:95)
at org.eclipse.xtext.resource.DefaultLocationInFilePr ovider.findNodeFor(DefaultLocationInFileProvider.j ava:321)
at org.eclipse.xtext.resource.DefaultLocationInFilePr ovider.doGetTextRegion(DefaultLocationInFileProvid er.java:77)
at org.eclipse.xtext.resource.DefaultLocationInFilePr ovider.getTextRegion(DefaultLocationInFileProvider .java:56)
at org.eclipse.xtext.resource.DefaultLocationInFilePr ovider.getFullTextRegion(DefaultLocationInFileProv ider.java:52)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding RegionProvider.computeObjectFolding(DefaultFolding RegionProvider.java:101)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding RegionProvider.computeObjectFolding(DefaultFolding RegionProvider.java:86)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding RegionProvider.doGetFoldingRegions(DefaultFoldingR egionProvider.java:68)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding RegionProvider$1.exec(DefaultFoldingRegionProvider .java:60)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding RegionProvider$1.exec(DefaultFoldingRegionProvider .java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWrit eAcces.readOnly(AbstractReadWriteAcces.java:32)
at org.eclipse.xtext.ui.editor.model.XtextDocument.re adOnly(XtextDocument.java:78)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding RegionProvider.getFoldingRegions(DefaultFoldingReg ionProvider.java:56)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding StructureProvider.calculateProjectionAnnotationMod el(DefaultFoldingStructureProvider.java:114)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding StructureProvider.initialize(DefaultFoldingStructu reProvider.java:58)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding StructureProvider.handleProjectionEnabled(DefaultF oldingStructureProvider.java:99)
at org.eclipse.xtext.ui.editor.folding.DefaultFolding StructureProvider$ProjectionChangeListener.project ionEnabled(DefaultFoldingStructureProvider.java:18 6)
at org.eclipse.jface.text.source.projection.Projectio nViewer.fireProjectionEnabled(ProjectionViewer.jav a:487)
at org.eclipse.jface.text.source.projection.Projectio nViewer.enableProjection(ProjectionViewer.java:535 )
at org.eclipse.jface.text.source.projection.Projectio nViewer.doOperation(ProjectionViewer.java:1414)
at org.eclipse.xtext.ui.editor.XtextEditor.installFol dingSupport(XtextEditor.java:476)
at org.eclipse.xtext.ui.editor.XtextEditor.createPart Control(XtextEditor.java:457)
at org.eclipse.ui.internal.e4.compatibility.Compatibi lityPart.createPartControl(CompatibilityPart.java: 138)
at org.eclipse.ui.internal.e4.compatibility.Compatibi lityEditor.createPartControl(CompatibilityEditor.j ava:96)
at org.eclipse.ui.internal.e4.compatibility.Compatibi lityPart.create(CompatibilityPart.java:313)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Nativ e Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Native MethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(De legatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.e4.core.internal.di.MethodRequestor.ex ecute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.proce ssAnnotated(InjectorImpl.java:861)
at org.eclipse.e4.core.internal.di.InjectorImpl.proce ssAnnotated(InjectorImpl.java:841)
at org.eclipse.e4.core.internal.di.InjectorImpl.injec t(InjectorImpl.java:113)
at org.eclipse.e4.core.internal.di.InjectorImpl.inter nalMake(InjectorImpl.java:321)
at org.eclipse.e4.core.internal.di.InjectorImpl.make( InjectorImpl.java:242)
at org.eclipse.e4.core.contexts.ContextInjectionFacto ry.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.internal.workbench.ReflectionCon tributionFactory.createFromBundle(ReflectionContri butionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionCon tributionFactory.doCreate(ReflectionContributionFa ctory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionCon tributionFactory.create(ReflectionContributionFact ory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.Contribu tedPartRenderer.createWidget(ContributedPartRender er.java:141)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.createWidget(PartRenderingEngine.java:8 94)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.safeCreateGui(PartRenderingEngine.java: 629)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.safeCreateGui(PartRenderingEngine.java: 731)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.access$2(PartRenderingEngine.java:702)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine$7.run(PartRenderingEngine.java:696)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner .java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.createGui(PartRenderingEngine.java:681)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRen derer.showTab(StackRenderer.java:1115)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStac kRenderer.postProcess(LazyStackRenderer.java:98)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.safeCreateGui(PartRenderingEngine.java: 645)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartR enderer.processContents(SWTPartRenderer.java:59)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.safeCreateGui(PartRenderingEngine.java: 641)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine$6.run(PartRenderingEngine.java:520)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.createGui(PartRenderingEngine.java:505)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementR eferenceRenderer.createWidget(ElementReferenceRend erer.java:74)
at org.eclipse.e4.ui.workbench.renderers.swt.Perspect iveRenderer.processContents(PerspectiveRenderer.ja va:59)
at org.eclipse.e4.ui.workbench.renderers.swt.Perspect iveStackRenderer.showTab(PerspectiveStackRenderer. java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.Perspect iveStackRenderer.postProcess(PerspectiveStackRende rer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRende rer.processContents(WBWRenderer.java:644)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine$9.run(PartRenderingEngine.java:987)
at org.eclipse.core.databinding.observable.Realm.runW ithDefault(Realm.java:332)
at org.eclipse.e4.ui.internal.workbench.swt.PartRende ringEngine.run(PartRenderingEngine.java:942)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.c reateAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench. java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWork bench(Workbench.java:543)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(Pl atformUI.java:149)
at org.openhab.designer.ui.internal.application.Appli cation.start(Application.java:48)
at org.eclipse.equinox.internal.app.EclipseAppHandle. run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseA ppLauncher.runApplication(EclipseAppLauncher.java: 110)
at org.eclipse.core.runtime.internal.adaptor.EclipseA ppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.ru n(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework( Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.ja va:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:14 38)
hab schon mal den OpenHab Designer neu installiert aber ohne erfolg.
Ich benutze einen Mac OS X 10.6.8 und habe den Openhab designer 1.2.0 installiert.
Vielen Dank im Voraus
Marcin
und im Detail :
Marcin
