OH 1.4 MySQL Persistence: Communications Links Failure
    seit OpenHAB Release 1.4 hat sich ja einiges getan im Bezug auf die MySQL Persistence. Leider auch soviel, dass ich sie nicht mehr zum Laufen bekomme:
    Neu aufgesetztes Debian Wheezy mit OpenHAB 1.4 (Stable) und MySQL 5.5.35.
    openhab.cfg:
    #### SQL Persistence Service  ####
    # the database url like 'jdbc:mysql://<host>:<port>/<user>'
    mysql:url=jdbc:mysql://localhost:3306/openhab
    mysql:user=openhab
    mysql:password=abc123
    Im logback.xml den Log-Level für "org.openhab.persistence" auf DEBUG gesetzt:
    ==> /var/log/openhab/events.log <==
    2014-02-16 23:35:49 - MySwitchItem received command OFF
    ==> /var/log/openhab/openhab.log <==
    23:35:49.591 DEBUG o.o.p.m.i.MysqlPersistenceService[:355]- mySQL: Attempting to connect to database jdbc:mysql://localhost:3306/openhab
    23:35:49.595 ERROR o.o.p.m.i.MysqlPersistenceService[:383]- mySQL: Failed connecting to the SQL database using: driverClass=com.mysql.jdbc.Driver, url=jdbc:mysql://localhost:3306/openhab, user=openhab, password=abc123
    [COLOR="Red"]com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure[/COLOR]
    The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.
            at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
            at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
            at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
            at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
            at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
            at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1121)
    Caused by: java.net.ConnectException: Connection refused
            at java.net.PlainSocketImpl.socketConnect(Native Method)
            at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:327)
            at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:193)
            at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:180)
            at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:385)
            at java.net.Socket.connect(Socket.java:546)
    23:35:49.595 WARN  o.o.p.m.i.MysqlPersistenceService[:268]- mySQL: No connection to database. Can not persist item 'MySwitchItem  (Type=SwitchItem, State=OFF)'! Will retry connecting to database next time.
    Versuch in der Shell mit lokalem MySQL zu connecten:
    user@mainserver:/opt/openhab/configurations/persistence# mysql -u openhab -p openhab
    Enter password:
    Reading table information for completion of table and column names
    You can turn off this feature to get a quicker startup with -A
    Welcome to the MySQL monitor.  Commands end with ; or \g.
    Your MySQL connection id is 2377
    Server version: 5.5.35-0+wheezy1 (Debian)
    Copyright (c) 2000, 2013, Oracle and/or its affiliates. All rights reserved.
    Oracle is a registered trademark of Oracle Corporation and/or its
    affiliates. Other names may be trademarks of their respective
    owners.
    Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
    mysql> [B]create table EXAMPLE( id INT);
    Query OK[/B], 0 rows affected (0.86 sec)
    mysql> drop table EXAMPLE;
    Query OK, 0 rows affected (0.06 sec)
    mysql>
    => An den Berechtigungen kann es also nicht liegen.
    Hat irgendjemand eine Idee, was ich noch versuchen kann?
    LG,
    Michael
    Ich hatte vor einiger Zeit auch das Problem, dass die Verbindung zu mySQL verloren ging. Allerdings reichte bei mir ein Neustart von mySQL und openHAB.
      Hilft bei mir leider nichts :-(
        Habe seit einiger Zeit das selbe Problem und die gleiche Fehlermeldung.
        Gibt es schon eine Lösung dazu?
        Michael
          Also bei mir hat es geholfen, eine Database "openhab" zu erzeugen.
          Dazu erst mit dem mysql-User "openhab" sich einloggen (zumindest geht das bei Linux so):
          mysql -u openhab -p
          Dann in mysql die Datenbank erzeugen:
          create database openhab;
          Mit quit wieder raus:
          quit
          Schon hat es funktioniert bei meinem openhab.cfg (hier ein Auszug):
          ############################ SQL Persistence Service ##################################
          mysql:url=jdbc:mysql://127.0.0.1/openhab
          # the database user
          mysql:user=openhab
          # the database password
          mysql:password=openhab
          Wär ganz hilfreich gewesen, wenn das in der Wiki drinstünde.
            in der openhab.cfg ist de connect-String falsch beschrieben. Dort steht
            Korrekterweise müsste es lauten:
            # the database url like 'jdbc:mysql://<host>:<port>/<database>'
            Vielleicht hat das bei einigen zur Verwirrung geführt. Im Wiki ist es übrigens richtig beschrieben.
            thoern
