Diverse Fehler im log
    ich wollte einmal die Fachleute hier fragen, ob im log Fehler sind, über die ich mir Gedanken machen sollte.
    root@openHAB:~# /etc/init.d/openhab stop
    [....] Stopping Open Home Automation Bus Daemon:.
    root@openHAB:~# /etc/init.d/openhab start
    [....] Starting Open Home Automation Bus Daemon:.
    root@openHAB:~# tail -f /opt/openhab/logs/openhab.log
    	at org.openhab.model.core.internal.folder.FolderObserver.checkFolder(FolderObserver.java:142)
    11:25:54.092 INFO  o.o.m.c.i.ModelRepositoryImpl[:97]- Refreshing model 'wenzel.items'
    11:25:54.168 ERROR o.o.m.c.i.f.FolderObserver[:105]- An unexpected exception has occured
    java.lang.NullPointerException: null
    	at org.openhab.model.item.binding.AbstractGenericBindingProvider.removeConfigurations(AbstractGenericBindingProvider.java:93)
    	at org.openhab.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:164)
    	at org.openhab.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:379)
    	at org.openhab.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:158)
    	at org.openhab.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:99)
    11:27:03.522 INFO  o.o.c.internal.CoreActivator[:61]- openHAB runtime has been started (v1.4.0).
    11:27:30.007 INFO  o.o.m.c.i.ModelRepositoryImpl[:79]- Loading model 'db4o.persist'
    11:27:33.203 INFO  o.o.m.c.i.ModelRepositoryImpl[:79]- Loading model 'wenzel.items'
    11:27:34.081 INFO  o.o.m.c.i.ModelRepositoryImpl[:79]- Loading model 'greent.items'
    11:27:45.962 INFO  o.o.m.c.i.ModelRepositoryImpl[:79]- Loading model 'wenzel.script'
    11:27:49.384 INFO  o.o.i.s.i.DiscoveryServiceImpl[:72]- mDNS service has been started
    11:27:59.743 INFO  o.o.m.c.i.ModelRepositoryImpl[:79]- Loading model 'wenzel.sitemap'
    11:28:08.753 INFO  o.o.io.rest.RESTApplication[:141]- Started REST API at /rest
    11:28:14.672 INFO  o.o.u.w.i.s.WebAppServlet[:79]- Started Classic UI at /openhab.app
    11:28:23.144 INFO  o.o.m.c.i.ModelRepositoryImpl[:79]- Loading model 'wenzel.rules'
    11:28:30.128 WARN  o.o.m.i.i.GenericItemProvider[:108]- Attempted to register a second BindingConfigReader of type 'autoupdate'. The primaraly reader will remain active!
    11:28:33.678 WARN  o.o.c.p.e.PersistenceExtensions[:404]- There is no queryable persistence service registered with the name 'db4o'
    11:28:33.708 ERROR o.o.m.r.i.engine.RuleEngine[:267]- Error during the execution of startup rule 'Update max and min temperatures': cannot invoke method public abstract org.openhab.core.types.State org.openhab.core.persistence.HistoricItem.getState() on null
    11:28:33.803 INFO  o.o.c.s.AbstractActiveService[:169]- Exec Refresh Service has been started
    11:28:34.259 INFO  o.o.c.s.AbstractActiveService[:169]- HTTP Refresh Service has been started
    11:28:34.760 INFO  o.o.c.s.AbstractActiveService[:169]- NTP Refresh Service has been started
    11:28:36.649 INFO  o.o.b.s.i.SysteminfoBinding[:397]- Using Sigar version 1.6.4.129
    11:28:36.750 INFO  o.o.c.s.AbstractActiveService[:169]- Systeminfo Refresh Service has been started
    11:28:46.136 INFO  o.o.b.k.i.c.KNXConnection[:202]- Established connection to KNX bus on 192.168.178.100:3671 in mode TUNNEL.
    11:28:56.356 WARN  o.o.b.k.i.bus.KNXBinding[:430]- Cannot read value for item 'Light_FF_Balcony_LED' from KNX bus: timeout waiting for group read response
    11:29:07.960 WARN  o.o.b.k.i.bus.KNXBinding[:430]- Cannot read value for item 'Light_FF_Balcony_LED' from KNX bus: timeout waiting for group read response
    11:29:19.039 WARN  o.o.b.k.i.bus.KNXBinding[:430]- Cannot read value for item 'Light_FF_Balcony_LED' from KNX bus: timeout waiting for group read response
    11:29:30.118 WARN  o.o.b.k.i.bus.KNXBinding[:430]- Cannot read value for item 'Light_FF_Balcony_LED' from KNX bus: timeout waiting for group read response
    Die letzte Warnung z.B. verhindert nicht, dass das Licht geschaltet wird aber vielleicht ist etwas an der KNX Installation zu tun?
    openHAB2 2.5.10 als Docker auf einen unRAID Server (Repository: openhab/openhab:latest-debian)
    Devices: KNX & ZWave
    Die Warnung kann zwei Ursachen haben: Entweder das Lesen Flag ist nicht gesetzt oder der Autor lässt sich aus irgend welchen Gründen nicht auslesen. Dann kannst Du es mal auf dem Status Objekt probieren, vielleicht geht es da.
    Zweite Möglichkeit: Die Buslast ist in dem Moment sehr hoch und deswegen kommt die Antwort nicht an, da müsstest Du mal nach schauen. Vielleicht kommt es z.B. zu sehr vielen Wiederholungstelegrammen?!
    Die NullPointerException kann ich nicht einschätzen.
      Vielen Dank Jockey, ich werde mal mit dem "Lesen Bit" Check starten, danach gehe ich die restlichen Dinge an.
      Große Buslast nehme ich nicht an, denn meine Installation ist eher klein:
      root@openHAB:/opt/openhab/configurations# ./installcheck.sh
      3 item files ====================
              1 Color items
              1 Contact items
              2 DateTime items
              13 Dimmer items
              3 Group items
              49 Number items
              7 Rollershutter items
              2 String items
              20 Switch items
      2 rules files ====================
              15 rules
              154 lines of code
      1 script files ====================
              1 lines of code
      2 sitemaps ====================
              14 frames
              115 lines of code
      10 transform files ====================
              2 map files
              8 xsl files
              102 lines of code
      Was ist damit gemeint?
        Dass du nicht das eigentliche Kommunikationobjekt des Aktors nutzt, sondern dessen Status-Objekt (muss aber am Aktor konfiguriert sein)
        thoern
