Ich denke wenn man tief in Java, xtext usw. drin ist, dann kennt man viele Sachen so wie z.B. Lambdas
Thomas
Thomas
<mapping name="WindowStatus2w"> <entry value="0" default="true"> <icon flavour="white" name="fts_window_2w"/> </entry> <entry value="1"> <icon flavour="white" name="fts_window_2w_tilt_l"/> </entry> <entry value="3"> <icon flavour="white" name="fts_window_2w_open_l"/> </entry> <entry value="4"> <icon flavour="white" name="fts_window_2w_tilt_r"/> </entry> <entry value="5"> <icon flavour="white" name="fts_window_2w_tilt_lr"/> </entry> <entry value="7"> <icon flavour="white" name="fts_window_2w_open_l_tilt_r"/> </entry> <entry value="12"> <icon flavour="white" name="fts_window_2w_open_r"/> </entry> <entry value="13"> <icon flavour="white" name="fts_window_2w_tilt_l_open_r"/> </entry> <entry value="15"> <icon flavour="white" name="fts_window_2w_open_lr"/> </entry> </mapping>
/** * Calculate the current state of a double window. * * @param ContactItem cItemTopLeft * Sensor top left. * @param ContactItem cItemBottomLeft * Sensor bottom left. * @param ContactItem cItemTopRight * Sensor top right. * @param ContactItem cItemBottomRight * Sensor bottom right. * * @return Number * Current state of window. */ val org.eclipse.xtext.xbase.lib.Functions$Function4 calculateWindowStateDouble = [ ContactItem cItemTopLeft, ContactItem cItemBottomLeft, ContactItem cItemTopRight, ContactItem cItemBottomRight | var int nState = 0 if (cItemTopLeft.state == CLOSED) { // Left window is tilted. nState = nState + 1 } if (cItemBottomLeft.state == CLOSED) { // Left window is open. nState = nState + 2 } if (cItemTopRight.state == CLOSED) { // Right window is tilted. nState = nState + 4 } if (cItemBottomRight.state == CLOSED) { // Right window is open. nState = nState + 8 } // Return state. return nState ] /** * Convert data of window contacts WindowBedroom1. */ rule "window contacts FF_Bedroom_1" when Item Window_FF_Bedroom_1 received update then logInfo("rules.window.contacts", "Window contacts [FF_Bedroom_1] received update") var int sum = 0 try { sum = calculateWindowStateDouble.apply(Window_FF_Bedroom_1_TL, Window_FF_Bedroom_1_BL, Window_FF_Bedroom_1_TR, Window_FF_Bedroom_1_BR) as Integer } catch (Exception e) { logInfo("rules.window.contacts", "Couldn't calculate state of window contacts [FF_Bedroom_1]") logDebug("rules.window.contacts", "Error: " + e.toString) } logInfo("rules.window.contacts", "state of WindowBedroom1: " + sum) WindowBedroom1.postUpdate(sum) end
[COLOR=#000]gFenster[/COLOR][COLOR=#660].[/COLOR][COLOR=#000]members[/COLOR][COLOR=#660].[/COLOR][COLOR=#000]filter[/COLOR][COLOR=#660]([/COLOR][COLOR=#000]s[/COLOR][COLOR=#660]|[/COLOR][COLOR=#000]s[/COLOR][COLOR=#660].[/COLOR][COLOR=#000]state[/COLOR][COLOR=#660]==[/COLOR][COLOR=#000]OPEN[/COLOR][COLOR=#660]).[/COLOR][COLOR=#000]size[/COLOR]
[COLOR=#c586c0]rule[/COLOR][COLOR=#ce9178]"Fensterkontakte State Changed"[/COLOR] [COLOR=#c586c0]when[/COLOR] [COLOR=#569cd6]Item[/COLOR][COLOR=#d4d4d4] gFensterkontakte received update [/COLOR][COLOR=#608b4e]// NOTE: the rule will trigger multiple times per event[/COLOR] [COLOR=#c586c0]then[/COLOR] [COLOR=#4ec9b0]Thread[/COLOR][COLOR=#c586c0]::[/COLOR][COLOR=#d4d4d4]sleep([/COLOR][COLOR=#b5cea8]500[/COLOR][COLOR=#d4d4d4]) [/COLOR][COLOR=#608b4e]// give persistence time to catch up[/COLOR] [COLOR=#569cd6]val[/COLOR][COLOR=#d4d4d4] haveHistory [/COLOR][COLOR=#d4d4d4]=[/COLOR][COLOR=#d4d4d4] gFensterkontakte[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]members[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]filter[c|c[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]lastUpdate([/COLOR][COLOR=#ce9178]"mapdb"[/COLOR][COLOR=#d4d4d4]) [/COLOR][COLOR=#d4d4d4]!==[/COLOR][COLOR=#569cd6]null[/COLOR][COLOR=#d4d4d4]][/COLOR] [COLOR=#569cd6]val[/COLOR][COLOR=#d4d4d4] mostRecent [/COLOR][COLOR=#d4d4d4]=[/COLOR][COLOR=#d4d4d4] haveHistory[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]sortBy[lastUpdate([/COLOR][COLOR=#ce9178]"mapdb"[/COLOR][COLOR=#d4d4d4])][/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]last[/COLOR] [COLOR=#c586c0]if[/COLOR][COLOR=#d4d4d4](mostRecent [/COLOR][COLOR=#d4d4d4]===[/COLOR][COLOR=#569cd6]null[/COLOR][COLOR=#d4d4d4]) logError([/COLOR][COLOR=#ce9178]"Test contacts"[/COLOR][COLOR=#d4d4d4], [/COLOR][COLOR=#ce9178]"Failed to find most recent"[/COLOR][COLOR=#d4d4d4])[/COLOR] [COLOR=#c586c0]else[/COLOR][COLOR=#c586c0]if[/COLOR][COLOR=#d4d4d4](mostRecent[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]state [/COLOR][COLOR=#d4d4d4]==[/COLOR][COLOR=#b5cea8]OPEN[/COLOR][COLOR=#d4d4d4]){[/COLOR] [COLOR=#569cd6]val[/COLOR][COLOR=#d4d4d4] dt [/COLOR][COLOR=#d4d4d4]=[/COLOR][COLOR=#d4d4d4] gKontakteZeit[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]members[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]filter[dt|dt[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]name [/COLOR][COLOR=#d4d4d4]==[/COLOR][COLOR=#d4d4d4] mostRecent[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]name[/COLOR][COLOR=#d4d4d4]+[/COLOR][COLOR=#ce9178]"_last_opened"[/COLOR][COLOR=#d4d4d4]][/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]head[/COLOR] [COLOR=#c586c0]if[/COLOR][COLOR=#d4d4d4](dt [/COLOR][COLOR=#d4d4d4]===[/COLOR][COLOR=#569cd6]null[/COLOR][COLOR=#d4d4d4]) logError([/COLOR][COLOR=#ce9178]"Test contacts"[/COLOR][COLOR=#d4d4d4], [/COLOR][COLOR=#ce9178]"Failed to find "[/COLOR][COLOR=#d4d4d4]+[/COLOR][COLOR=#d4d4d4] mostRecent[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]name[/COLOR][COLOR=#d4d4d4]+[/COLOR][COLOR=#ce9178]"_last_opened"[/COLOR][COLOR=#d4d4d4])[/COLOR] [COLOR=#c586c0]else[/COLOR][COLOR=#d4d4d4] dt[/COLOR][COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]postUpdate([/COLOR][COLOR=#569cd6]new[/COLOR][COLOR=#4ec9b0]DateTimeType[/COLOR][COLOR=#d4d4d4])[/COLOR] [COLOR=#d4d4d4] }[/COLOR] [COLOR=#c586c0]end[/COLOR]
[COLOR=#c586c0]rule[/COLOR][COLOR=#ce9178]"Test rule"[/COLOR] [COLOR=#c586c0]when[/COLOR] [COLOR=#569cd6]Item[/COLOR][COLOR=#d4d4d4] gFenster received update [/COLOR][COLOR=#608b4e]// NOTE: the rule will trigger multiple times per event[/COLOR] [COLOR=#c586c0]then[/COLOR] [COLOR=#4ec9b0]Thread[/COLOR][COLOR=#c586c0]::[/COLOR][COLOR=#d4d4d4]sleep([/COLOR][COLOR=#b5cea8]500[/COLOR][COLOR=#d4d4d4]) [/COLOR][COLOR=#608b4e]// give persistence time to catch up[/COLOR] [COLOR=#569cd6]val[/COLOR][COLOR=#d4d4d4] AnzahlFenster [/COLOR][COLOR=#d4d4d4]=[/COLOR] [COLOR=#000]gFenster[/COLOR][COLOR=#660].[/COLOR][COLOR=#000]members[/COLOR][COLOR=#660].[/COLOR][COLOR=#000]filter[/COLOR][COLOR=#660]([/COLOR][COLOR=#000]s[/COLOR][COLOR=#660]|[/COLOR][COLOR=#000]s[/COLOR][COLOR=#660].[/COLOR][COLOR=#000]state[/COLOR][COLOR=#660]==[/COLOR][COLOR=#000]OPEN[/COLOR][COLOR=#660]).[/COLOR][COLOR=#000]size[/COLOR] Summe_offene_Fenster_Item[COLOR=#d4d4d4].[/COLOR][COLOR=#d4d4d4]postUpdate([/COLOR][COLOR=#569cd6]AnzahlFenster[/COLOR][COLOR=#d4d4d4])[/COLOR] [COLOR=#c586c0]end[/COLOR]
