so funktioniert dank @udo1toni und @Ea Sy für alle die nachmachen wollen
rule "init"
when
System started
then
Sonne.sendCommand(OFF)
end
rule "Sonnen"
when
Item Sunrise_Event received update ON
then
sendCommand(Sonne, OFF)
end
rule "Sonnen"
when
Item Sunset_Event received update ON
then
sendCommand(Sonne, ON)
end
Sitemap:
Text item=Sunrise_Time visibility=[Sonne==ON]
Text item=Sunset_Time visibility=[Sonne!=ON]
