Hilfe von den python-GURUS erbeten!
    Ich habe mir im Bereich python etwas zerschossen und brauhe eine Hilfestellung.
    Es gehen einige Befehle zum Upgrade nicht mehr, wie
    root@ibbgateway:/home/smarthome# pip install --upgrade python-apt
    Irgendetwas mit "LSB" spukt hier herum!
    Bitte 2 Worte mehr bei einer Erklärung, python ist leider eune Fremdsprache für mich!
    Exception:
    File "/usr/local/lib/python3.4/dist-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
    File "/usr/local/lib/python3.4/dist-packages/pip/commands/install.py", line 272, in run
    with self._build_session(options) as session:
    File "/usr/local/lib/python3.4/dist-packages/pip/basecommand.py", line 72, in _build_session
    insecure_hosts=options.trusted_hosts,
    File "/usr/local/lib/python3.4/dist-packages/pip/download.py", line 329, in __ init__
    self.headers["User-Agent"] = user_agent()
    File "/usr/local/lib/python3.4/dist-packages/pip/download.py", line 93, in user_agent
    from pip._vendor import distro
    File "/usr/local/lib/python3.4/dist-packages/pip/_vendor/distro.py", line 1050, in <module>
    _distro = LinuxDistribution()
    File "/usr/local/lib/python3.4/dist-packages/pip/_vendor/distro.py", line 594, in __init__
    if include_lsb else {}
    File "/usr/local/lib/python3.4/dist-packages/pip/_vendor/distro.py", line 933, in _get_lsb_release_info
    raise subprocess.CalledProcessError(code, cmd, stdout)
    subprocess.CalledProcessError: Command 'lsb_release -a' returned non-zero exit status 1
    File "/usr/local/bin/pip", line 11, in <module>
    sys.exit(main())
    File "/usr/local/lib/python3.4/dist-packages/pip/__init__.py", line 233, in main
    return command.main(cmd_args)
    File "/usr/local/lib/python3.4/dist-packages/pip/basecommand.py", line 251, in main
    timeout=min(5, options.timeout)) as session:
    File "/usr/local/lib/python3.4/dist-packages/pip/download.py", line 329, in __init__
    File "/usr/local/lib/python3.4/dist-packages/pip/_vendor/distro.py", line 594,in __init__
    File "/usr/local/lib/python3.4/dist-packages/pip/_vendor/distro.py", line 933,in _get_lsb_release_info
    Danke für jeden Hinweis!
    Wolfgang
