im log fallen mir folgende WARNING Meldungen beim startup auf:
ist das normal ? kann mir die bitte jemand erklären ?
mache ich da etwas falsch ?
build: 1.3x.ee85750.dev in /usr/local/smarthome
Gruß Wil
2017-08-11 10:50:06 INFO Main Start Logics
2017-08-11 10:50:06 INFO Main Loading '/usr/local/smarthome/lib/env/logic.yaml' to 'OrderedDict'
2017-08-11 10:50:06 INFO Main Loading '/usr/local/smarthome/etc/logic.yaml' to 'OrderedDict'
2017-08-11 10:50:06 INFO Main Start Plugins
2017-08-11 10:50:06 WARNING smartvisu Installing widgets into smartVISU
2017-08-11 10:50:06 INFO smartvisu install_widgets: Installing from '/usr/local/smarthome' to '/var/www/html/smartvisu'
2017-08-11 10:50:06 INFO smartvisu installwidgets: Creating directory for widgets
2017-08-11 10:50:06 INFO smartvisu install_widgets: Removing old dynamic widget files
2017-08-11 10:50:06 WARNING smartvisu findinsertline: No insert point for pattern {% if isfile('pages/'~config_pages~'/visu.js') %}
2017-08-11 10:50:06 WARNING smartvisu findinsertline: No insert point for pattern {% if isfile('pages/'~config_pages~'/visu.css') %}
2017-08-11 10:50:06 INFO smartvisu Loading '/usr/local/smarthome/etc/plugin.yaml' to 'OrderedDict'
2017-08-11 10:50:06 INFO simulation Starting Simulation
2017-08-11 10:50:06 INFO smartvisu Adding import statements to root.html
2017-08-11 10:50:06 WARNING smartvisu Generating pages for smartVISU
2017-08-11 10:50:06 INFO smartvisu copy_templates: Copying template 'widgetblock_blk_noh.html' from plugin to smartVISU
2017-08-11 10:50:06 INFO BackendServer [11/Aug/2017:10:50:06] ENGINE Serving on http://192.168.178.41:8383
2017-08-11 10:50:09 INFO Main VISU: Websocket handler uses protocol version 4
2017-08-11 10:50:11 INFO hello Hello World!
Gruß Wil
