also Dank stackoverflow bin ich ein mini schritt weiter. Die URL wird korrekt zusammen gebaut...leider bleibt der http error. Es ist also vermutlich ein decode problem.
2018-04-26 21:45:09 INFO sms sms -------------->http://gateway.sms77.io/api/sms?u=us...text=ALARMtest -- sms.py:<module>:14
2018-04-26 21:45:09 INFO _cplogging CP Server Thread-8 192.168.10.10 - admin [26/Apr/2018:21:45:09] "POST /logics.html HTTP/1.1" 200 13063 "http://192.168.10.110:8383/logics.html" "Mozilla/5.0 (Windows NT 6.1; WOW64; rv:53.0) Gecko/20100101 Firefox/53.0" -- _cplogging.py:access:285
2018-04-26 21:45:09 DEBUG __init__ Main KNX[default]: 1.0.30 read 0/3/103 -- __init__.py
arse_telegram:373
2018-04-26 21:45:09 DEBUG __init__ Main KNX[default]: 1.0.101 set 0/3/103 to 00 -- __init__.py
arse_telegram:339
2018-04-26 21:45:09 ERROR scheduler sms Logic: sms, File: /usr/lib/python3.4/urllib/request.py, Line: 579, Method: http_error_default, Exception: HTTP Error 400: Bad Request -- scheduler.py:_task:394
Traceback (most recent call last):
File "/usr/local/smarthomeNG/lib/scheduler.py", line 382, in _task
exec(obj.bytecode)
File "/usr/local/smarthomeNG/logics/sms.py", line 15, in <module>
site = urllib.request.urlopen(url)
File "/usr/lib/python3.4/urllib/request.py", line 153, in urlopen
return opener.open(url, data, timeout)
File "/usr/lib/python3.4/urllib/request.py", line 461, in open
response = meth(req, response)
File "/usr/lib/python3.4/urllib/request.py", line 571, in http_response
'http', request, response, code, msg, hdrs)
File "/usr/lib/python3.4/urllib/request.py", line 499, in error
return self._call_chain(*args)
File "/usr/lib/python3.4/urllib/request.py", line 433, in _call_chain
result = func(*args)
File "/usr/lib/python3.4/urllib/request.py", line 579, in http_error_default
raise HTTPError(req.full_url, code, msg, hdrs, fp)
urllib.error.HTTPError: HTTP Error 400: Bad Request
arse_telegram:3732018-04-26 21:45:09 DEBUG __init__ Main KNX[default]: 1.0.101 set 0/3/103 to 00 -- __init__.py
arse_telegram:3392018-04-26 21:45:09 ERROR scheduler sms Logic: sms, File: /usr/lib/python3.4/urllib/request.py, Line: 579, Method: http_error_default, Exception: HTTP Error 400: Bad Request -- scheduler.py:_task:394
exec(obj.bytecode)
