Backend Error 500 nach Update 1.5.1
    nach Update auf Release 1.5.1 bekomme ich immer den Fehler
    Oops, Error 500:
    The server encountered an unexpected condition which prevented it from fulfilling the request.
    beim aufrufen des Backend angezeigt.
    Update habe ich gmacht mit
    – cd smarthome
    – git pull
    – cd plugins
    – git pull
    im Log ist dies zu finden beim aufruf der Backend
    Request Headers:
      CONNECTION: keep-alive
      ACCEPT: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
      USER-AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:61.0) Gecko/20100101 Firefox/61.0
      ACCEPT-ENCODING: gzip, deflate
      ACCEPT-LANGUAGE: de,en-US;q=0.7,en;q=0.3
      UPGRADE-INSECURE-REQUESTS: 1
      HOST: 192.167.127.100:8383
      Remote-Addr: 192.167.127.177
    2018-08-14  18:32:05 ERROR    CP Server Thread-7 [14/Aug/2018:18:32:05] HTTP
      File "/usr/local/lib/python3.5/dist-packages/cherrypy/_cprequest.py", line 631, in respond
        self._do_respond(path_info)
      File "/usr/local/lib/python3.5/dist-packages/cherrypy/_cprequest.py", line 690, in _do_respond
        response.body = self.handler()
      File "/usr/local/lib/python3.5/dist-packages/cherrypy/lib/encoding.py", line 221, in __call__
        self.body = self.oldhandler(*args, **kwargs)
      File "/usr/local/lib/python3.5/dist-packages/cherrypy/_cpdispatch.py", line 60, in __call__
        return self.callable(*self.args, **self.kwargs)
      File "/usr/local/smarthome/plugins/backend/__init__.py", line 293, in index
        return self.render_template('index.html')
      File "/usr/local/smarthome/plugins/backend/__init__.py", line 275, in render_template
        self.find_visu_plugin()
      File "/usr/local/smarthome/plugins/backend/__init__.py", line 248, in find_visu_plugin
        for p in self._sh._plugins:
    AttributeError: 'SmartHome' object has no attribute '_plugins'
    2018-08-14  18:32:05 INFO     CP Server Thread-7 192.167.127.177 - - [14/Aug/2018:18:32:05] "GET /backend/ HTTP/1.1" 500 732 "" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:61.0) Gecko/20100101 Firefox/61.0"
    2018-08-14  18:32:05 INFO     CP Server Thread-7 192.167.127.177 - - [14/Aug/2018:18:32:05] "GET /gstatic/fontawesome/svg-with-js/css/fa-svg-with-js.css HTTP/1.1" 200 7407 "http://192.167.127.100:8383/backend/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:61.0) Gecko/20100101 Firefox/61.0"
    2018-08-14  18:32:05 INFO     CP Server Thread-8 192.167.127.177 - - [14/Aug/2018:18:32:05] "GET /gstatic/bootstrap/css/bootstrap.min.css HTTP/1.1" 200 142041 "http://192.168.27.8:8383/backend/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:61.0) Gecko/20100101 Firefox/61.0"
    Hab ich was beim Upade vergessen?
    Danke für die Hilfe
    Die Zeilennummern in den Fehlermeldungen zeigen, dass Du auf jeden Fall nicht das aktuelle Backend Plugin installiert (weder aus master noch aus develop). Ist Dein git pull ohne Fehler durchgelaufen?
    Ich vermute, dass alle Plugins bei Dir noch aus dem alten Release sind.
    Martin
      Hab ich einen fehler gemacht ?
      ich bin auf
      usr/local/smarthome/plugins gegangen und habe dort git pull gemacht.
      Eine Fehlermeldung ist mit nicht aufgefallen.
      Allerdings kommt jetzt wenn ich es nochmal versuche.
      Im Moment auf keinem Branch.
      Bitte geben Sie den Branch an, welchen Sie zusammenführen möchten.
      Siehe git-pull(1) für weitere Details.
          git pull <Remote-Repository> <Branch>
      Zuletzt geändert von bmx; 15.08.2018, 08:45.
        GELÖST
        mit
        git pull https://github.com/smarthomeNG/plugins
        hats geklappt :-)
