ich beitreibe die neueste master version von smarthomeNG auf zwei Raspis
beide zeigen eine Startzeit von 1970:
[B]Item-Informationen[/B] [TABLE] [TR] Attribut Wert [/TR] [TR] [TD]Pfad[/TD] [TD]env.system.start[/TD] [/TR] [TR] [TD]Name[/TD] [TD]env.system.start[/TD] [/TR] [TR] [TD]Typ (type)[/TD] [TD]foo[/TD] [/TR] [TR] [TD]Wert (value)[/TD] [TD]1970-03-19 07:43:20.826663+01:00[/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [/TR] [TR] Änderungsinformationen: [/TR] [TR] [TD]Letztes Update[/TD] [TD]2018-10-07 15:39:38.868664+02:00[/TD] [/TR] [TR] [TD]Letzte Änderung[/TD] [TD]2018-10-07 15:39:38.868248+02:00[/TD] [/TR] [TR] [TD]Alter (Update)[/TD] [TD]1 Tag, 5 Stunden, 28 Minuten, 5 Sekunden[/TD] [/TR] [TR] [TD]Alter (Änderung)[/TD] [TD]1 Tag, 5 Stunden, 28 Minuten, 5 Sekunden[/TD] [/TR] [TR] [TD]Update durch[/TD] [TD]Logic 'env_init'[/TD] [/TR] [TR] [TD]Geändert durch[/TD] [TD]Logic 'env_init'[/TD] [/TR] [TR] [TD]vorheriger Wert[/TD] [TD]None[/TD] [/TR] [TR] [TD]vorheriges Update[/TD] [TD]2018-10-07 15:39:28.752386+02:00[/TD] [/TR] [TR] [TD]vorherige Änderung[/TD] [TD]2018-10-07 15:39:28.752271+02:00[/TD] [/TR] [TR] [TD]vorh. Alter (Update)[/TD] [TD]10.12 Sekunden[/TD] [/TR] [TR] [TD]vorh. Alter (Änderung)[/TD] [TD]10.12 Sekunden[/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [/TR] [TR] Initialisierungs-, Trigger- und Evaluations-Konfiguration: [/TR] [TR] [TD]cache[/TD] [TD]off[/TD] [/TR] [TR] [TD]enforce_updates[/TD] [TD]off[/TD] [/TR] [TR] [TD]eval_trigger[/TD] [TD]-[/TD] [/TR] [TR] [TD]eval[/TD] [TD]-[/TD] [/TR] [TR] [TD]on_update[/TD] [TD]-[/TD] [/TR] [TR] [TD]on_change[/TD] [TD]-[/TD] [/TR] [TR] [TD]log_change[/TD] [TD]-[/TD] [/TR] [TR] [TD]cycle[/TD] [TD]-[/TD] [/TR] [TR] [TD]crontab[/TD] [TD]-[/TD] [/TR] [TR] [TD]autotimer[/TD] [TD]-[/TD] [/TR] [TR] [TD]threshold[/TD] [TD]-[/TD] [/TR] [TR] [TD] [/TD] [TD] [/TD] [/TR] [TR] Verbundene Trigger: [/TR] [TR] [TD="colspan: 2"]bound method WebSocket.update_item of plugins.visu_websocket.WebSo [/TD] [/TR] [/TABLE]
# Check Time
while datetime.date.today().isoformat() < '2014-03-16': # XXX update date
time.sleep(5)
print("Waiting for updated time.")
self.logger.info("Waiting for updated time.")
# system start #start = sh.now() - datetime.timedelta(seconds=psutil.boot_time()) start = shtime.now() - datetime.timedelta(seconds=psutil.boot_time()) sh.env.system.start(start, logic.lname)
# system start start = datetime.datetime.fromtimestamp(psutil.boot_time(),tz=shtime.tzinfo()) sh.env.system.start(start, logic.lname)
sh.env.core.start(shtime.now(), logic.lname)
psutil.boot_time()
