Error beim Aufrufen des Backends
    ich kann das Backend nicht aufrufen; Habe heute eine 1.4er - Installation auf 1.5 upgedated. Im Log kommt folgender Fehler:
    2019-02-02  16:43:34 ERROR    CP Server Thread-8 [02/Feb/2019:16:43:34] HTTP
      File "/usr/local/lib/python3.5/dist-packages/cherrypy/_cprequest.py", line 631, in respond
        self._do_respond(path_info)
      File "/usr/local/lib/python3.5/dist-packages/cherrypy/_cprequest.py", line 690, in _do_respond
        response.body = self.handler()
      File "/usr/local/lib/python3.5/dist-packages/cherrypy/lib/encoding.py", line 221, in __call__
        self.body = self.oldhandler(*args, **kwargs)
      File "/usr/local/lib/python3.5/dist-packages/cherrypy/_cpdispatch.py", line 60, in __call__
        return self.callable(*self.args, **self.kwargs)
      File "/usr/local/smarthome/plugins/backend/__init__.py", line 293, in index
        return self.render_template('index.html')
      File "/usr/local/smarthome/plugins/backend/__init__.py", line 275, in render_template
        self.find_visu_plugin()
      File "/usr/local/smarthome/plugins/backend/__init__.py", line 248, in find_visu_plugin
        for p in self._sh._plugins:
    AttributeError: 'SmartHome' object has no attribute '_plugins'
    2019-02-02  16:43:34 INFO     CP Server Thread-8 [02/Feb/2019:16:43:34] HTTP
    Request Headers:
      ACCEPT-ENCODING: gzip, deflate
      CACHE-CONTROL: max-age=0
      HOST: 192.168.1.107:8383
      CONNECTION: keep-alive
      ACCEPT: text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
      ACCEPT-LANGUAGE: de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7
      USER-AGENT: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.98 Safari/537.36
      REFERER: http://192.168.1.107:8383/
      UPGRADE-INSECURE-REQUESTS: 1
      Remote-Addr: 192.168.1.160
    2019-02-02  16:43:34 INFO     CP Server Thread-8 192.168.1.160 - - [02/Feb/2019:16:43:34] "GET /backend/ HTTP/1.1" 500 3905 "http://192.168.1.107:8383/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.98 Safari/537.36"
    2019-02-02  16:43:35 INFO     CP Server Thread-8 192.168.1.160 - - [02/Feb/2019:16:43:35] "GET /gstatic/img/favicon.ico HTTP/1.1" 200 26166 "http://192.168.1.107:8383/backend/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.98 Safari/537.36"
    Kann jemand sagen was ich hier fixen muss?
    Dankeschön.
    VG
    Dieter
    Dieter
    Bist Du sicher, dass Du auch die Plugins auf v1.5 upgedated hast?
    Martin
      dann werde ich das nochmal neu installieren.
      VG
      Dieter
      Dieter
