Hallo zusammen,,
ich bin gerade dabei SHNG v1.5.1 auf einem Thin Client zu installieren.
Dies hat soweit geklappt bis auf diesen Schritt:
darauf erhalte ich folgende Ausgabe und der Vorgang beendet sich
Wie kann ich nun die version aiohttp 3 installieren? sodass die Requirements erfüllt sind?
pip3 install -r requirements/all.txt
root@SHNG:/usr/local/smarthome# pip3 install -r requirements/all.txt
Ignoring requests: markers 'python_version == "3.2"' don't match your environment
Requirement already satisfied: PyMVGLive>=1.1.4 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 10)) (1.1.4)
Requirement already satisfied: cherrypy>=8.1.2 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 16)) (18.1.0)
Requirement already satisfied: ephem>=3.7 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 19)) (3.7.6.0)
Requirement already satisfied: jinja2>=2.9 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 25)) (2.10)
Requirement already satisfied: miflora>=0.4 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 28)) (0.5)
Requirement already satisfied: minimalmodbus>=0.7 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 31)) (0.7)
Requirement already satisfied: nokia==0.4.0 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 34)) (0.4.0)
Requirement already satisfied: paho-mqtt>=1.2.2 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 37)) (1.4.0)
Requirement already satisfied: psutil in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 40)) (5.6.1)
Requirement already satisfied: pyatv==0.3.9 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 43)) (0.3.9)
Requirement already satisfied: pyhomematic>=0.1.28 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 46)) (0.1.58)
Requirement already satisfied: pyserial>=3.2.1 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 51)) (3.4)
Requirement already satisfied: python-dateutil>=2.5.3 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 58)) (2.8.0)
Requirement already satisfied: python-magic>=0.4.12 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 61)) (0.4.15)
Requirement already satisfied: python-telegram-bot>=9.0.0 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 64)) (11.1.0)
Requirement already satisfied: requests>=2.9.1 in /usr/lib/python3/dist-packages (from -r requirements/all.txt (line 91)) (2.12.4)
Requirement already satisfied: ruamel.yaml<=0.15,>=0.13.7 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 94)) (0.15.0)
Requirement already satisfied: scapy-python3>=0.18 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 97)) (0.26)
Requirement already satisfied: sleekxmpp>=1.3.1 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 100)) (1.3.3)
Requirement already satisfied: telepot>=8.3 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 103)) (12.7)
Requirement already satisfied: tinytag>=0.18.0 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 106)) (1.0.0)
Requirement already satisfied: urllib3>=1.9.1 in /usr/lib/python3/dist-packages (from -r requirements/all.txt (line 110)) (1.19.1)
Requirement already satisfied: websocket-client>=0.44.0 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 113)) (0.55.0)
Requirement already satisfied: xmltodict>=0.11.0 in /usr/local/lib/python3.5/dist-packages (from -r requirements/all.txt (line 116)) (0.12.0)
Requirement already satisfied: more-itertools in /usr/local/lib/python3.5/dist-packages (from cherrypy>=8.1.2->-r requirements/all.txt (line 16)) (6.0.0)
Requirement already satisfied: zc.lockfile in /usr/local/lib/python3.5/dist-packages (from cherrypy>=8.1.2->-r requirements/all.txt (line 16)) (1.4)
Requirement already satisfied: portend>=2.1.1 in /usr/local/lib/python3.5/dist-packages (from cherrypy>=8.1.2->-r requirements/all.txt (line 16)) (2.3)
Requirement already satisfied: cheroot>=6.2.4 in /usr/local/lib/python3.5/dist-packages (from cherrypy>=8.1.2->-r requirements/all.txt (line 16)) (6.5.4)
Requirement already satisfied: MarkupSafe>=0.23 in /usr/local/lib/python3.5/dist-packages (from jinja2>=2.9->-r requirements/all.txt (line 25)) (1.1.1)
Requirement already satisfied: btlewrap>=0.0.4 in /usr/local/lib/python3.5/dist-packages (from miflora>=0.4->-r requirements/all.txt (line 28)) (0.0.4)
Requirement already satisfied: requests-oauthlib>=0.4.2 in /usr/local/lib/python3.5/dist-packages (from nokia==0.4.0->-r requirements/all.txt (line 34)) (1.2.0)
Requirement already satisfied: requests-oauth>=0.4.1 in /usr/local/lib/python3.5/dist-packages (from nokia==0.4.0->-r requirements/all.txt (line 34)) (0.4.1)
Requirement already satisfied: arrow>=0.4 in /usr/local/lib/python3.5/dist-packages (from nokia==0.4.0->-r requirements/all.txt (line 34)) (0.13.1)
Requirement already satisfied: srptools>=0.2.0 in /usr/local/lib/python3.5/dist-packages (from pyatv==0.3.9->-r requirements/all.txt (line 43)) (1.0.0)
Requirement already satisfied: ed25519<2,>=1.4 in /usr/local/lib/python3.5/dist-packages (from pyatv==0.3.9->-r requirements/all.txt (line 43)) (1.4)
Requirement already satisfied: curve25519-donna<2,>=1.3 in /usr/local/lib/python3.5/dist-packages (from pyatv==0.3.9->-r requirements/all.txt (line 43)) (1.3)
Requirement already satisfied: cryptography>=1.8.1 in /usr/local/lib/python3.5/dist-packages (from pyatv==0.3.9->-r requirements/all.txt (line 43)) (2.6.1)
Collecting aiohttp<3,>=2.3.0 (from pyatv==0.3.9->-r requirements/all.txt (line 43))
Using cached https://files.pythonhosted.org/packages/24/9e/9e7e8955fd2db59e96bfe7d9da13b29171772006af0edeb60851788fff86/aiohttp-2.3.10-cp35-cp35m-manylinux1_i686.whl
Requirement already satisfied: zeroconf>=0.17.7 in /usr/local/lib/python3.5/dist-packages (from pyatv==0.3.9->-r requirements/all.txt (line 43)) (0.21.3)
Requirement already satisfied: six>=1.5 in /usr/lib/python3/dist-packages (from python-dateutil>=2.5.3->-r requirements/all.txt (line 58)) (1.10.0)
Requirement already satisfied: certifi in /usr/local/lib/python3.5/dist-packages (from python-telegram-bot>=9.0.0->-r requirements/all.txt (line 64)) (2019.3.9)
Requirement already satisfied: future>=0.16.0 in /usr/local/lib/python3.5/dist-packages (from python-telegram-bot>=9.0.0->-r requirements/all.txt (line 64)) (0.17.1)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from zc.lockfile->cherrypy>=8.1.2->-r requirements/all.txt (line 16)) (33.1.1)
Requirement already satisfied: tempora>=1.8 in /usr/local/lib/python3.5/dist-packages (from portend>=2.1.1->cherrypy>=8.1.2->-r requirements/all.txt (line 16)) (1.14)
Requirement already satisfied: backports.functools-lru-cache in /usr/local/lib/python3.5/dist-packages (from cheroot>=6.2.4->cherrypy>=8.1.2->-r requirements/all.txt (line 16)) (1. 5)
Requirement already satisfied: oauthlib>=3.0.0 in /usr/local/lib/python3.5/dist-packages (from requests-oauthlib>=0.4.2->nokia==0.4.0->-r requirements/all.txt (line 34)) (3.0.1)
Requirement already satisfied: asn1crypto>=0.21.0 in /usr/local/lib/python3.5/dist-packages (from cryptography>=1.8.1->pyatv==0.3.9->-r requirements/all.txt (line 43)) (0.24.0)
Requirement already satisfied: cffi!=1.11.3,>=1.8 in /usr/local/lib/python3.5/dist-packages (from cryptography>=1.8.1->pyatv==0.3.9->-r requirements/all.txt (line 43)) (1.12.2)
Requirement already satisfied: yarl>=1.0.0 in /usr/local/lib/python3.5/dist-packages (from aiohttp<3,>=2.3.0->pyatv==0.3.9->-r requirements/all.txt (line 43)) (1.3.0)
Requirement already satisfied: async-timeout>=1.2.0 in /usr/local/lib/python3.5/dist-packages (from aiohttp<3,>=2.3.0->pyatv==0.3.9->-r requirements/all.txt (line 43)) (3.0.1)
Requirement already satisfied: multidict>=4.0.0 in /usr/local/lib/python3.5/dist-packages (from aiohttp<3,>=2.3.0->pyatv==0.3.9->-r requirements/all.txt (line 43)) (4.5.2)
Requirement already satisfied: chardet in /usr/lib/python3/dist-packages (from aiohttp<3,>=2.3.0->pyatv==0.3.9->-r requirements/all.txt (line 43)) (2.3.0)
Requirement already satisfied: idna-ssl>=1.0.0 in /usr/local/lib/python3.5/dist-packages (from aiohttp<3,>=2.3.0->pyatv==0.3.9->-r requirements/all.txt (line 43)) (1.1.0)
Requirement already satisfied: ifaddr in /usr/local/lib/python3.5/dist-packages (from zeroconf>=0.17.7->pyatv==0.3.9->-r requirements/all.txt (line 43)) (0.1.6)
Requirement already satisfied: pytz in /usr/local/lib/python3.5/dist-packages (from tempora>=1.8->portend>=2.1.1->cherrypy>=8.1.2->-r requirements/all.txt (line 16)) (2018.9)
Requirement already satisfied: jaraco.functools>=1.20 in /usr/local/lib/python3.5/dist-packages (from tempora>=1.8->portend>=2.1.1->cherrypy>=8.1.2->-r requirements/all.txt (line 1 6)) (2.0)
Requirement already satisfied: pycparser in /usr/local/lib/python3.5/dist-packages (from cffi!=1.11.3,>=1.8->cryptography>=1.8.1->pyatv==0.3.9->-r requirements/all.txt (line 43)) ( 2.19)
Requirement already satisfied: idna>=2.0 in /usr/lib/python3/dist-packages (from yarl>=1.0.0->aiohttp<3,>=2.3.0->pyatv==0.3.9->-r requirements/all.txt (line 43)) (2.2)
telepot 12.7 has requirement aiohttp>=3.0.0, but you'll have aiohttp 2.3.10 which is incompatible.
Installing collected packages: aiohttp
Found existing installation: aiohttp 3.5.4
Uninstalling aiohttp-3.5.4:
Successfully uninstalled aiohttp-3.5.4
Successfully installed aiohttp-2.3.10
