Force sending value even if the value is the same
    Hello, i've a little problem.
    i've a shutter item to up or down :
    salon:
        volet:
            updown:
                type: bool
                knx_dpt: 1
                knx_send: 11/0/20
    When i send salon.volet.updown(1) the shutter opens and when i send salon.volet.updown(0) the shutter closes.
    The problem SHNG record the last command i send and don't send again if i send the same value.
    For exemple i send : salon.volet.updown(1) and i send a stop event if i re send salon.volet.updown(1) nothing append because the item is already set to 1 ...
    is there any solution to do this ? or i need to make a logik ?
    Thanks a lot.
    Set enforce_updates to True for that item
    Martin
      oh ! Yeah of course ! Thanks a lot it work's
      thank you for your speed !
