MQTT : Befehle ausführen
    ich habe eine Miele Waschmaschine mit Miele@Home - Dafür benutze ich die Miele 3rd party API - Nun würde ich gerne die Maschine per MQTT an SHNG anbinden.
    Dies ist das MQTT der Miele
    [URL="https://github.com/oklona/Miele-MQTT/blob/master/miele-MQTT.php"]https://github.com/oklona/Miele-MQTT...miele-MQTT.php[/URL]
    Jedoch bekomme ich garnichts hin ..
    curl -X GET "https://api.mcs3.miele.com/v1/devices/?language=de" -H "accept: application/json; charset=utf-8" -H "Authorization: Bearer XXXXXXXXX"
    damit erhalte ich folgende ausgabe :
    { "000149834615": { "ident": { "type": { "key_localized": "Gerätetyp", "value_raw": 1, "value_localized": "Waschmaschine" }, "deviceName": "", "deviceIdentLabel": { "fabNumber": "xxxxx", "fabIndex": "11", "techType": "WWI660", "matNumber": "xxxxxx", "swids": [ "4418", "20456", "25213" ] }, "xkmIdentLabel": { "techType": "EK037", "releaseVersion": "03.65" } }, "state": { "ProgramID": { "value_raw": 1, "value_localized": "Baumwolle", "key_localized": "Programmbezeichnung" }, "status": { "value_raw": 9, "value_localized": "Abbruch", "key_localized": "Status" }, "programType": { "value_raw": 1, "value_localized": "Eigenes Programm", "key_localized": "Programmart" }, "programPhase": { "value_raw": 256, "value_localized": "", "key_localized": "Programmphase" }, "remainingTime": [ 0, 0 ], "startTime": [ 0, 0 ], "targetTemperature": [ { "value_raw": 6000, "value_localized": 60, "unit": "Celsius" }, { "value_raw": -32768, "value_localized": null, "unit": "Celsius" }, { "value_raw": -32768, "value_localized": null, "unit": "Celsius" } ], "temperature": [ { "value_raw": -32768, "value_localized": null, "unit": "Celsius" }, { "value_raw": -32768, "value_localized": null, "unit": "Celsius" }, { "value_raw": -32768, "value_localized": null, "unit": "Celsius" } ], "signalInfo": false, "signalFailure": false, "signalDoor": false, "remoteEnable": { "fullRemoteControl": true, "smartGrid": true }, "light": 0, "elapsedTime": [ 0, 0 ], "spinningSpeed": { "unit": "U/min", "value_raw": 1600, "value_localized": "1600", "key_localized": "Schleuderdrehzahl" }, "dryingStep": { "value_raw": null, "value_localized": "", "key_localized": "Trockenstufe" }, "ventilationStep": { "value_raw": null, "value_localized": "", "key_localized": "Lüfterstufe" }, "plateStep": [] } } }[B]Response headers[/B]
    wie kann man dies nun sinnvoll in SHNG eibinden und Später dazu noch eine Logik für den sogeannten Smartstart erstellen wenn PV Überschuss vorhanden ist.
    Zuletzt geändert von jonny7792; 23.01.2020, 20:38.
    Gruss Oliver
    Projektleiter Technische Gebäudeausrüstung
    Nutze das MQTT Plugin
    Martin
      Das verlinkte script, nutzt anscheinend den Miele REST Service und setzt diesen auf mqtt um.
        Du kannst Du in einer Logik von der Webadresse die Du oben angegeben hast die Daten Abfragen. Das das JSON ist, kannst Du das eigentlich auch direkt in ein dict überführen und mit dem Inhalt des dicts dann Deine Items befüllen.
            "000149834615": {
                "ident": {
                    "type": {
                        "value_raw": 1,
                    "deviceName": "",
                        "fabIndex": "11",
                        "swids": [
                            "4418",
                            "20456",
                            "25213"
                    "xkmIdentLabel": {
                "state": {
                    "ProgramID": {
                        "value_raw": 1,
                    "status": {
                        "value_raw": 9,
                    "programType": {
                        "value_raw": 1,
                    "programPhase": {
                        "value_raw": 256,
                    "remainingTime": [
                        0,
                    "startTime": [
                        0,
                            "value_raw": 6000,
                            "unit": "Celsius"
                            "unit": "Celsius"
                            "unit": "Celsius"
                    "temperature": [
                            "unit": "Celsius"
                            "unit": "Celsius"
                            "unit": "Celsius"
                    "remoteEnable": {
                        "smartGrid": true
                    "light": 0,
                    "elapsedTime": [
                        0,
                    "spinningSpeed": {
                        "unit": "U/min",
                        "value_raw": 1600,
                    "dryingStep": {
                        "value_raw": null,
                        "value_raw": null,
                    "plateStep": []
        Mit dem Python Modul requests kannst Du den curl abbilden. Du hast jetzt nicht geschrieben, ob die Miele noch irgendeinen Parameter gesendet bekommen muß. In dem Fall findet sich hier lesenswertes.
        Um json dann in ein dict zu überführen hilft das Python Modul json. Auch hier hat Stackoverflow die Antworten.
          Ja genau so ist es ,
          Mir sind vorallem Meldungen wie Waschmaschine Fertig sowie die Verbrauchswerte wichtig sodass ich diese visualisieren kann und die waMa aus der Logik raus starten kann
          https://api.mcs3.miele.com/v1/devices/?language=de" -H "accept: application/json; charset=utf-8" -H "Authorization: Bearer CH_xyyyyyy""
          > SyntaxError: invalid syntax
          Zuletzt geändert von jonny7792; 24.01.2020, 19:15.
          Gruss Oliver
            Ach ja, mir fällt gerade auf, das das Plugin jsonread eigentlich genau für Dein Problem eine Lösung bieten sollte
              Guten Morgen , ich schaue es mir mal an
              Gruss Oliver
                Ich hatte mal das Plugin probier leider ohne Erfolgt.
                Ich muss zur Autorisierung einen curl befehl absetzen dieser wie folgt aufgebaut ist:
                curl -X GET "https://api.mcs3.miele.com/v1/devices/?language=de" -H "accept: application/json; charset=utf-8" -H "Authorization: Bearer CH_41acccc32secretxxxxxxxx"
                alternativ kann ich diese datei aufrufen : miele-MQTT.php
                php miele-MQTT.php
                Data for appliance: 000149834615
                Appliance type: Washing Machine
                Program status: Finished
                Program type: 1
                Program phase: Anti-crease
                Time left: 00:00
                Time elapsed: 00:00
                Gruss Oliver
                  Ich kucke morgen Mal kurz danach, bin zwar auch kein pro, kann aber das Plugin Grundgerüst stellen
                  Zuletzt geändert von Bonze; 02.02.2020, 21:32.
                    Super danke dir schonmal Bonze
                    Sofern du dann den genauen secret benötigst kannst du mich kontaktieren
                    Gruss Oliver
                      Ich hab irgendwie mit dem oauth2 Probleme,
                      hat da jemand zufällig Erfahrung mit requests_oauth? Oder sollte man lieber die requests abfragen von Hand zu Fuss zusammenbauen, wie bei dem Beispiel Script?
                      Ich bekomme beim oauth2 immer Fehler 503 , wenn ich wenigstens da den richtigen Ansatz hätte..
