plot.rtr not working in sv_heading_center
    Hi there,
    I try to plot my RTR values into top of room page using sv_heading_center.
    haus:[INDENT]wohnen:[/INDENT][INDENT=2]name: Wohnzimmer
    sv_page: room
    sv_img: scene_livingroom.svg
    sv_nav_aside: "{{ basic.float('item.name', 'haus.wohnen.temp', '°') }}"
    #sv_heading_center: "{{ basic.float('item.name', 'haus.wohnen.temp', '°') }} {{ plot.rtr('item-plot', 'item', 'item.setpoint', 'item.state') }} {{ basic.float('item.name', 'haus.wohnen.temp', '°') }}"
    #sv_heading_center: "{{ plot.rtr('c1, 'haus.wohnen.temperature', 'haus.wohnen.temperature.setpoint', 'haus.wohnen.temperature.state') }}"
    sv_heading_center: "{{ plot.rtr('c1, 'haus.wohnen.temperature', 'haus.wohnen.temperature.setpoint', 'haus.wohnen.temperature.state') }}"[/INDENT]
    ....[INDENT=3]temperature:[/INDENT][INDENT=4]name: Temperatur Graph
    type: num
    knx_dpt: 9
    knx_cache: 3/1/3
    knx_status: 3/1/3
    sqlite: 'yes'
    visu_acl: rw
    #sv_widget: "{{ device.rtr('item', 'item.name', 'item', 'item.setpoint', 'item.mode', 'item.night', 'item.frost', 'item.state') }}"
    sv_widget: "{{ plot.rtr('item-plot', 'item', 'item.setpoint', 'item.state') }}"
    setpoint:[/INDENT][INDENT=5]type: num
    sqlite: 'yes'
    visu_acl: rw
    knx_dpt: 9
    knx_cache: 3/2/6
    knx_send: 3/2/6[/INDENT][INDENT=4]
    state:[/INDENT][INDENT=5]type: num
    sqlite: 'yes'
    visu_acl: rw
    knx_dpt: 5001
    knx_cache: 1/1/6
    knx_send: 1/1/6[/INDENT]
    ruslts in smartVISU
    Error occurred in twig-template engine! error:
    Unexpected character "'".
    file: haus.wohnen.html
    line: 68
    HTML-Code:
    * @package smartVISU
    * @author Martin Gleiß
    * @copyright 2012
    * @license GPL [http://www.gnu.de]
    {% extends "rooms.html" %}
    {% block content %}
    <h1><img class="icon" src='{{ icon0 }}scene_livingroom.svg' />Wohnzimmer</h1>
    <div class="preblock">
    <table width="100%">
    <tr>
    <td align="left">
    </td>
    <td align="center">
    </td>
    <td align="right">
    </td>
    </tr>
    </table>
    </div>
    <div class="block">
    <div class="set-2" data-role="collapsible-set" data-theme="c" data-content-theme="a" data-mini="true">
    <div data-role="collapsible" data-collapsed="false">
    <h3>Light All</h3>
    {{ device.dimmer('ds1', 'Gang', 'haus.wohnen.light.desk.state', 'haus.wohnen.light.desk.level')}} <br> {{ device.dimmer('ds2', 'CouchTisch', 'haus.wohnen.light.couch.state', 'haus.wohnen.light.couch.level') }} <br> {{ device.dimmer('ds3', 'EssTisch', 'haus.wohne$
    </div>
    </div>
    </div>
    <div class="block">
    <h3>Shutter</h3>
    <br> {{ device.shutter ('haus.wohnen.blind', 'Shutter', 'haus.wohnen.blind.move', '', 'haus.wohnen.blind.pos') }} <br><br>
    </div>
    </div>
    </div>
    <div class="block">
    <h3>Temperatur</h3>
    {{ device.rtr('haus.wohnen.temp', 'Temperatur', 'haus.wohnen.temp', 'haus.wohnen.temp.setpoint', 'haus.wohnen.temp.mode', 'haus.wohnen.temp.night', 'haus.wohnen.temp.frost', 'haus.wohnen.temp.state') }}
    </div>
    </div>
    </div>
    <div class="block">
    <h3>Temperatur Graph</h3>
    {{ plot.rtr('haus.wohnen.temperature-plot', 'haus.wohnen.temperature', 'haus.wohnen.temperature.setpoint', 'haus.wohnen.temperature.state') }}
    </div>
    </div>
    </div>
    {% endblock %}
    If I use
    sv_heading_center: "{{ basic.float('f1', 'haus.wohnen.temperature', '°') }} {{ plot.rtr('c2', 'haus.wohnen.temperature', 'haus.wohnen.temperature.setpoint', 'haus.wohnen.temperature.state') }} {{ basic.float('f2', 'haus.wohnen.temperature', '°') }}"
    SmarVISU page room page has no errer but.
    - basic.float is working
    - plot.rtr is not shown
    Can anybody help out there?
    Zuletzt geändert von hansenpaul; 04.02.2020, 14:53.
    Just a quick guess: try to replace "item-plot" with "c2" or so in case the dash does cause trouble ...
      yes you are right tanks a lot
      Zuletzt geändert von hansenpaul; 04.02.2020, 14:51.
