Ursache für "Database dump Database"
    in meinem Log sehe ich sehr häufig:
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch SELECT time, item_id, duration, val_str, val_num, val_bool, changed FROM log WHERE item_id = 98 AND time = 1586090654233;: []
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch INSERT INTO log(item_id, time, val_str, val_num, val_bool, duration, changed) VALUES (98,1586090654233,None,3611.9270833333417,1,5383,1 586090673884);: <sqlite3.Cursor object at 0x7f2cbf916730>
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch SELECT time, item_id, duration, val_str, val_num, val_bool, changed FROM log WHERE item_id = 98 AND time = 1586090659616;: []
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch INSERT INTO log(item_id, time, val_str, val_num, val_bool, duration, changed) VALUES (98,1586090659616,None,3611.9791666666665,1,5270,1 586090673884);: <sqlite3.Cursor object at 0x7f2cbf916730>
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch SELECT time, item_id, duration, val_str, val_num, val_bool, changed FROM log WHERE item_id = 98 AND time = 1586090664886;: []
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch INSERT INTO log(item_id, time, val_str, val_num, val_bool, duration, changed) VALUES (98,1586090664886,None,3612.0312500000105,1,5356,1 586090673884);: <sqlite3.Cursor object at 0x7f2cbf916730>
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch SELECT time, item_id, duration, val_str, val_num, val_bool, changed FROM log WHERE item_id = 98 AND time = 1586090670242;: []
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch INSERT INTO log(item_id, time, val_str, val_num, val_bool, duration, changed) VALUES (98,1586090670242,None,3612.0833333333358,1,None,1 586090673884);: <sqlite3.Cursor object at 0x7f2cbf916730>
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch UPDATE item SET time = 1586090670242, val_str = None, val_num = 3612.0833333333358, val_bool = 1, changed = 1586090673884 WHERE id = 98;: <sqlite3.Cursor object at 0x7f2cbf916730>
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch SELECT id, name, time, val_str, val_num, val_bool, changed from item WHERE name = eg.Kueche.heizung.stellwert;: (144, 'eg.Kueche.heizung.stellwert', 1586090510617, None, 7.8, 1, 1586090553366)
    2020-04-05 14:44:33 DEBUG Database dump Dumping eg.Kueche.heizung.stellwert/144 with 2 values
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch SELECT time, item_id, duration, val_str, val_num, val_bool, changed FROM log WHERE item_id = 144 AND time = 1586090510617;: [(1586090510617, 144, None, None, 7.8, 1, 1586090553366)]
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch UPDATE log SET duration = 127987, val_str = None, val_num = 7.8, val_bool = 1, changed = 1586090673928 WHERE item_id = 144 AND time = 1586090510617;: <sqlite3.Cursor object at 0x7f2cbf916730>
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch SELECT time, item_id, duration, val_str, val_num, val_bool, changed FROM log WHERE item_id = 144 AND time = 1586090638604;: []
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch INSERT INTO log(item_id, time, val_str, val_num, val_bool, duration, changed) VALUES (144,1586090638604,None,5.9,1,None,1586090673928); : <sqlite3.Cursor object at 0x7f2cbf916730>
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch UPDATE item SET time = 1586090638604, val_str = None, val_num = 5.9, val_bool = 1, changed = 1586090673928 WHERE id = 144;: <sqlite3.Cursor object at 0x7f2cbf916730>
    2020-04-05 14:44:33 DEBUG Database dump Database: Fetch SELECT id, name, time, val_str, val_num, val_bool, changed from item WHERE name = eg.Arbeit.heizung.ist;: (193, 'eg.Arbeit.heizung.ist', 1586090266616, None, 24.75, 1, 1586090315913)
    Ist das normal? Was macht es?
    Hendrik
    Das kommt wenn ein Eintrag in die db geschrieben wird. Stell das log Level auf info oder warn, wenn alles nach plan läuft
      Ok, danke!
