<div class="center">
{{ now|smartdate('l') }}, {{ now|smartdate('d.m.Y') }}<br/>
<img src="lib/weather/pics/sun_up.png" class="sunIcon"/> {{ basic.print('sonnenaufgang', 'system.datum_uhrzeit.sonne.aufgang', 'text') }} <img src="lib/weather/pics/sun_down.png" class="sunIcon"//> {{ basic.print('sonnenuntergang', 'system.datum_uhrzeit.sonne.untergang','text') }}
<img src="lib/weather/pics/moon_up.png" class="moonIcon" /> {{ basic.print('mondaufgang', 'system.datum_uhrzeit.mond.aufgang', 'text') }} <img src="lib/weather/pics/moon_down.png" class="moonIcon"//>{{ basic.print('moonset', 'system.datum_uhrzeit.mond.untergang','text') }}<br/>
Also Danke für die heutigen Hilfe
Ich habe jetzt alles was vor dem Fehler ablief rausgenommen. im Admin sind alle Felder des Items "System" vorhanden,
aber in der Log-Anzeige meckert der Neustart,
2020-04-17 11:38:00 WARNING lib.logic CallListCSVLogic: Could not access logic file (/usr/local/smarthome/logics/calllist_csv_logic.py) => ignoring.
2020-04-17 11:38:02 WARNING __main__ DEPRECATED: Used function 'sh.tzinfo()', called in 'class Item (lib.item)' by '__run_eval -> _task -> _worker -> run -> _bootstrap_inner -> _bootstrap' - use the Shtime-API instead
2020-04-17 11:38:02 ERROR lib.item Item system.datum_uhrzeit.sonne.position: problem running <bound method WebSocket.update_item of <plugins.visu_websocket.WebSocket object at 0x695b39b0>>: you can only create an ephem.Angle through ephem.degrees() or ephem.hours()
Traceback (most recent call last):
File "/usr/local/smarthome/lib/item.py", line 2368, in __update
method(self, caller, source, dest)
File "/usr/local/smarthome/plugins/visu_websocket/__init__.py", line 156, in update_item
self.websocket.update_item(item.id(), item(), source)
File "/usr/local/smarthome/lib/item.py", line 2124, in __call__
return copy.deepcopy(self._value)
File "/usr/lib/python3.7/copy.py", line 150, in deepcopy
y = copier(x, memo)
File "/usr/lib/python3.7/copy.py", line 220, in _deepcopy_tuple
y = [deepcopy(a, memo) for a in x]
File "/usr/lib/python3.7/copy.py", line 220, in <listcomp>
File "/usr/lib/python3.7/copy.py", line 180, in deepcopy
y = _reconstruct(x, memo, *rv)
File "/usr/lib/python3.7/copy.py", line 274, in _reconstruct
y = func(*args)
File "/usr/lib/python3.7/copyreg.py", line 88, in __newobj__
return cls.__new__(cls, *args)
TypeError: you can only create an ephem.Angle through ephem.degrees() or ephem.hours()
2020-04-17 11:38:03 ERROR lib.item Item system.datum_uhrzeit.mond.position: problem running <bound method WebSocket.update_item of <plugins.visu_websocket.WebSocket object at 0x695b39b0>>: you can only create an ephem.Angle through ephem.degrees() or ephem.hours()
y = copier(x, memo)
y = func(*args)
y = copier(x, memo)
y = func(*args)
y = copier(x, memo)
y = func(*args)
Die Posiition spreche in der Visu nicht an.
In 1.7 lief es schon einmal! Was mache ich falsch?
