Question about issue with HTTPS usage for smartVisu on SmartHomeNG
    Hello everyone, Hope its ok to post here in English.
    First of all, I would like to thank everyone here for creating/maintaining SmartHomeNG and SmartVisu. Finally found something I could get working rather quickly with my KNX installation.
    I have it working on the default HTTP pages, and can switch/dim any lights in my house and see each room temperature via the SmartVisu pages with knxd to the KNX bus.
    I then installed Certbot and 3rd party plugin to get a wildcard domain cert, verified by DNS entry, and certs are stored in /etc/letsencrypt/live/<domainname>/.
    I will use them also to copy over-to/use-in a few other devices in the house (NAS, router etc).
    My issue is that when I switch from http://<IPaddress>/smartvisu to httpS://<IPaddress>/smartvisu , I only see (header) texts and picture place holders. See below 2 pictures. (<IPaddress> would be like 192.168.x.x)
    I've tried a few things but dont know what else I am missing/ can try.
    Any help would be appreciated.
    In below, 'wildcard domain' is like '*.home.net', <domain name> is 'home.net', <hostname>.<domain name> is then 'smart.home.net'
    Added to: /etc/nginx/conf.d/https.conf
    server_name <hostname>.<domain name>;
    ssl_certificate /etc/letsencrypt/live/<domain name>/fullchain.pem;
    ssl_certificate_key /etc/letsencrypt/live/<domain name>/privkey.pem;
    ssl_trusted_certificate /etc/letsencrypt/live/<domain name>/fullchain.pem;
    I also tried:
    server_name <hostname>.<domain name> <domain name>;
    or
    server_name <domain name>;
    I also tried creating an extra file in /etc/nginx/conf.d with name <domain name>.conf and/or <hostname>.<domain name>.conf.
    Both being copies of https.conf with server_name adjusted accordingly.
    Build/setup:
    • Hardware: Raspberry Pi 3
    • Started with the Rasbian Image "Debian Buster, SmarthomeNG 1.7.1"
    • Apt-get update + apt-get upgrade
    • setup_all -> changed language to English, TZ: Europe/Dublin,
    • knxd enabled, SSH enabled,samba: disabled, nginx:enabled, reverse proxy: skip, fail2ban:disabled, NFS:enable, Lirc:disable, Monit:disable, Exim4:enabled, Logcheck:disabled, Mosquite:enabled, OpenVPN:enabled, InfluxDB:enabled, Grafana:enabled,
    • Changed SSH port from 22 to 10022
    system_update -> updated environment:
    SmartHomeNG version 1.7.2.master, Python version 3.7.3 final, SmartVise v2.9.b.Development, knxd v0.14.30
    That is because modern Browsers don't allow mixtures of entcrypted Traffic and unencrypted Traffic on the same page.
    You have to use wss:// instead of ws:// protocol on the page. For that you have to configure the visu_websocket plugin for wss:// (it does only support ws:// or wss://, not both). The plugin doesn't use the certificates at the locations you named. You have to have the certificate in the smarthome/ect directory.
    And you have to configure the smartVISU for using wss://. It has been discussed in the smartVISU forum.
    Martin
