Blinker.py konfigurieren
  • Jürgen
    Hallo Morg,
    tut nich:
    2021-01-17 15:03:54 ERROR logics.visual_alarm Logic: logics.visual_alarm, File: /usr/local/smarthome/logics/blinker.py, Line: 49, Method: <module>, Exception: isinstance expected 2 arguments, got 1
    > Traceback (most recent call last):
    > File "/usr/local/smarthome/lib/scheduler.py", line 590, in _task
    > exec(obj.bytecode)
    > File "/usr/local/smarthome/logics/blinker.py", line 49, in <module>
    > if not isinstance(blink_items_anticyclic):
    > TypeError: isinstance expected 2 arguments, got 1
    Gruß Jürgen
  • Morg
    #!/usr/bin/env python3
    # vim: tabstop=4 softtabstop=4 shiftwidth=4 expandtab
    # LOGIC config
    # visual_alarm:
    #     filename: blinker.py
    #     watch_item: HOME.alarm.action.blinkinglight
    #     set_items_cyclic:
    #         - AUSSEN.south.light.outer
    #         - AUSSEN.west.light.outer
    #     set_items_anticyclic:
    #         - AUSSEN.south.light.inner
    #         - AUSSEN.east.light.door
    #         - AUSSEN.west.light.nested
    #     set_blink_cycles: -1 ' -1: endless
    #     set_blink_interval: 2
    #     dry_run: 0
    control_item_name = trigger['source']
    control_item = sh.return_item(control_item_name)
    triggered_by = trigger['by']
    if control_item is not None:
        logger.info(f'LOGIC blinker.py: {logic.name} triggered from source {control_item_name} by {triggered_by}')
        # control_item_active = trigger['value']
        control_item_active = control_item()
        # set parameters from logic config
        blink_items_cyclic = []
        if hasattr(logic, 'set_items_cyclic'):
            blink_items_cyclic = logic.set_items_cyclic
        if isinstance(blink_items_cyclic, str):
            blink_items_cyclic = [blink_items_cyclic, ]
        # do we have blink items?
        if not isinstance(blink_items_cyclic, list) or len(blink_items_cyclic) == 0:
            logger.info('LOGIC blinker.py: error, no cyclic blink items set. Aborting')
        else:
            blink_items_anticyclic = []
            if hasattr(logic, 'set_items_anticyclic'):
                blink_items_anticyclic = logic.set_items_anticyclic
            if isinstance(blink_items_anticyclic, str):
                blink_items_anticyclic = [blink_items_anticyclic, ]
            # did we get strange data?
            if hasattr(logic, 'set_blink_cycles'):
                blink_cycles = int(logic.set_blink_cycles)
            else:
                blink_cycles = 2
                logger.info(f'LOGIC blinker.py: no blink cycles set, setting to default: {blink_cycles}')
            if hasattr(logic, 'set_blink_interval'):
                blink_interval = int(logic.set_blink_interval)
            else:
                blink_interval = 2
                logger.info(f'LOGIC blinker.py: no blink interval set, setting to default: {blink_interval}')
            if hasattr(logic, 'dry_run'):
                dry_run = (int(logic.dry_run) > 0)
            else:
                dry_run = False
            if control_item_active:
                # first call?
                if not hasattr(logic, 'blink_init'):
                    logger.info(f'LOGIC blinker.py: initiating {blink_cycles} blinks for {len(blink_items_cyclic)} cyclic and {len(blink_items_anticyclic)} anti-cyclic items')
                    logic.blink_init = True
                    blink_items = blink_items_cyclic + blink_items_anticyclic
                    if len(blink_items) > 0:
                        # SAVE item states
                        logic.saved_items = {}
                        for item_name in blink_items:
                            item = sh.return_item(item_name)
                            logic.saved_items[item_name] = item()
                            logger.info(f'LOGIC blinker.py: save {item_name} = {item()}')
                        if dry_run:
                            logger.warn('LOGIC blinker.py: test mode, dry run active')
                    else:
                        logger.warn('LOGIC blinker.py: no blink items set')
                # prepare blink
                if hasattr(logic, 'blink_value'):
                    logic.blink_value = not logic.blink_value
                else:
                    logic.blink_value = True
                if hasattr(logic, 'blink_countdown'):
                    logic.blink_countdown -= 1
                else:
                    logic.blink_countdown = blink_cycles
                # any blinks left?
                if logic.blink_countdown > 0 or blink_cycles == -1:
                    if blink_cycles == -1:
                        logger.info('LOGIC blinker.py BLINK (endless)')
                    else:
                        logger.info(f'LOGIC blinker.py BLINK ({logic.blink_countdown} cycles remaining)')
                    # set all cyclic items
                    for item_name in blink_items_cyclic:
                        logger.info(f'LOGIC blinker.py SET {item_name} to {logic.blink_value}')
                        if not dry_run:
                            item(logic.blink_value)
                    # set all anti-cyclic items
                    for item_name in blink_items_anticyclic:
                        logger.info(f'LOGIC blinker.py SET {item_name} to {not logic.blink_value}')
                        if not dry_run:
                            item(not logic.blink_value)
                    sh.trigger(f'logics.{logic.name}', by=trigger['by'], source=trigger['source'], value=trigger['value'], dt=sh.now() + datetime.timedelta(seconds=blink_interval))
                else:
                    logger.info('LOGIC blinker.py countdown finished, set control item to False')
                    control_item(False)  # this triggers logic again!
            else:
                logger.info('LOGIC blinker.py control item set to false: stop blink logic, restore saved item values')
                # RESTORE item states
                if hasattr(logic, 'saved_items'):
                    for item_name in logic.saved_items:
                        value = logic.saved_items[item_name]
                        logger.info(f'LOGIC blinker.py: restore {item_name} = {item()}')
                        if not dry_run:
                            item(value)
                # reset persistent values
                    delattr(logic, 'saved_items')
                    delattr(logic, 'blink_countdown')
                    delattr(logic, 'blink_value')
                if hasattr(logic, 'blink_init'):
                    delattr(logic, 'blink_init')
    else:
        logger.info('LOGIC blinker.py triggered without source... ignoring...')
  • Morg
    Ups. Danke für den Input bzgl. des letzten Else, mag sein, dass das "verloren" gegangen ist.
    Es muss heißen "if not isinstance(blink_items_cyclic, list) or..."
  • Jürgen
    Hallo Morg,
    wird nicht geladen, die letzte Else am Ende wird angemeckert...
    Habe den mal nach rechts unte das letzte if eingerückt, dann wird das Plugin geladen,
    klappt aber nicht:
    2021-01-17  11:36:35 ERROR    logics.visual_alarm Logic: logics.visual_alarm, File: /usr/local/smarthome/logics/blinker.py, Line: 38, Method: <module>, Exception: isinstance expected 2 arguments, got 1
    >     exec(obj.bytecode)
    >   File "/usr/local/smarthome/logics/blinker.py", line 38, in <module>
    >     if not isinstance(blink_items_cyclic) or len(blink_items_cyclic) == 0:
    Gruß Jürgen
    Zuletzt geändert von Jürgen; 17.01.2021, 11:38.
  • Morg
    Probier mal den Code. Habe ich jetzt nicht getestet, aber ich hoffe, ich habe keine Fehler reingebaut
    Verlangt kein anticyclic und geht damit um, wenn da Unsinn drin steht.
    # LOGIC config
    # visual_alarm:
    #     set_items_cyclic:
    #     dry_run: 0
        else:
            else:
                blink_cycles = 2
            else:
                blink_interval = 2
            else:
                dry_run = False
                # first call?
                        # SAVE item states
                        if dry_run:
                    else:
                # prepare blink
                else:
                else:
                # any blinks left?
                    else:
                        if not dry_run:
                        if not dry_run:
                else:
            else:
                        if not dry_run:
                            item(value)
        else:
    Für einen zweiten Blinker müsste es eigentlich reichen, eine zweite Logik mit derselben Datei zu konfigurieren, die dann entsprechend eigene Einstellungen hat....
  • Jürgen
    Hallo Morg,
    - NONE
    klappt nicht:
    > File "/usr/local/smarthome/logics/blinker.py", line 68, in <module>
    > TypeError: 'NoneType' object is not callable
    : NONE
    auch nicht:
    > File "/usr/local/smarthome/logics/blinker.py", line 62, in <module>
    > TypeError: can only concatenate list (not "str") to list
    Noch jemand ne Idee?
    Ich habe jetzt ein Dummy Device definiert, nun schaltet sich aber auch immer mein WatchItem nach Ende des Blinkens wieder aus :-(
    Ich mach erstmal Schluss, das wird heute nix mehr :-(
    Gruß Jürgen
  • Morg
    Du könntest auch versuchen:
    set_items_anticyclic: NONE
    oder
    set_items_anticyclic: []
    Dann hat er den Parameter, im zweiten Fall sogar ne Liste und dann - mal schauen.
  • Jürgen
    Hallo Andre,
    perfekt! Die Else nach links und alles OK. Hab ich aber so aus der Doku übernommen. :-)
    Bleibt noch die Frage, wie ich den einen 2. Blinker realisiere...
    Gruß Jürgen
  • AndreK
    Hi Jürgen ,
    ich vermute im Beispiel ist die Einrückung verrutscht :
    Beispiel :
          logger.info("LOGIC blinker.py: initiating {0} blinks for {1} cyclic and {2} anti-cyclic items".format(blink_cycles, len(blink_items_cyclic), len(blink_items_anticyclic)))
            # SAVE item states
              logger.info("LOGIC blinker.py: save {0} = {1}".format(item_name, item()))
          if dry_run == True:
            logger.warn("LOGIC blinker.py: test mode, dry run active")
          else:
            logger.warn("LOGIC blinker.py: no blink items set")
    ich würde vermuten richtig wäre :
            # SAVE item states
    [MARKIEREN]        if dry_run == True:
              logger.warn("LOGIC blinker.py: test mode, dry run active")[/MARKIEREN]
          else:
    Ich interpretiere die Meldung "LOGIC blinker.py: no blink items set" soll nur ausgegeben werden wenn
    len(blink_items) <= 0
    Die "Dryrun"-Meldung soll ausgegeben werden wenn
    und
    dry_run == True
    Gruss Andre
  • Jürgen
    Hallo Morg,
    Done, geht auch nicht, den Parameter will er haben:
    2021-01-16 17:01:06 ERROR logics.visual_alarm Logic: logics.visual_alarm, File: /usr/local/smarthome/logics/blinker.py, Line: 59, Method: <module>, Exception: name 'blink_items_anticyclic' is not defined
    > exec(obj.bytecode)
    > File "/usr/local/smarthome/logics/blinker.py", line 59, in <module>
    > NameError: name 'blink_items_anticyclic' is not defined
    2021-01-16 17:01:17 ERROR logics.visual_alarm Logic: logics.visual_alarm, File: /usr/local/smarthome/logics/blinker.py, Line: 59, Method: <module>, Exception: name 'blink_items_anticyclic' is not defined
    > exec(obj.bytecode)
    Aber mit einem anderen Ziel funktioniert es:
    - Erdgeschoss.Arbeitszimmer.Licht.Schreibtischlicht
    Nun will ich aber nicht zwingend etwas zusätzlich schalten, also muss ich wohl ein Dummy Item anlegen, oder?
    Noch eine Frage:
    Wenn ich einen zweiten Blinker benötige, lege ich dann nach gleichem Muster eine Blinker2.py an?
    In der Config sehe ich keine sprechende Möglichkeit für ein zweites überwachtes Item und die entsprechenden Ausgaben.
    Nachtrag:
    Obwohl es bei zwei Items funktioniert, kommt bei jeder Sequenz ein Syslog Eintrag:
    2021-01-16 17:29:12 WARNING logics.visual_alarm LOGIC blinker.py: no blink items set
    Laut Code kommt das immer, wenn der dry mode nicht gesetzt ist, macht doch keinen Sinn...
    PHP-Code:
    if dry_run == Truelogger.warn("LOGIC blinker.py: test mode, dry run active")
    else:
    Jürgen
    Zuletzt geändert von Jürgen; 16.01.2021, 17:35.
  • Morg
    Kommentiere mal set_items_anticyclic aus. Das ist eine leere Liste und funktioniert so nicht.
  • Jürgen
    hat ein Thema erstellt Blinker.py konfigurieren.
    ich versuche das Blinker.py (https://www.smarthomeng.de/blinken-per-logik) zu nutzen, klappt leider nicht:
    Soll: Wenn Deckenlicht eingeschaltet wird, soll Schranklicht 4x blinken (Macht keinen Sinn, ist aber einfach zu kontrollieren ;-) )
    Das blinker.py habe ich als Text von der Webseite kopiert und im Verzeichnis /logics/blinker.py abgelegt
    Hier meine /etc/logic.yaml:
    visual_alarm:
    watch_item: Erdgeschoss.Arbeitszimmer.Licht.Deckenlicht
    set_items_cyclic:
    - Erdgeschoss.Arbeitszimmer.Licht.Schranklicht
    set_blink_cycles: 4 # -1 for endless loop
    set_blink_interval: 4
    dry_run: 0
    Das Admin Tool zeigt beide Items als bool an:
    Item Pfad Erdgeschoss.Arbeitszimmer.Licht.Schranklicht
    Item Name Erdgeschoss.Arbeitszimmer.Licht.Schranklicht
    Datentyp bool
    Item Pfad Erdgeschoss.Arbeitszimmer.Licht.Deckenlicht
    Item Name Erdgeschoss.Arbeitszimmer.Licht.Deckenlicht
    Datentyp bool
    Hier der Fehler im Logfile, den ich leider nicht verstehe:
    2021-01-16 15:50:36 ERROR logics.visual_alarm Logic: logics.visual_alarm, File: /usr/local/smarthome/logics/blinker.py, Line: 62, Method: <module>, Exception: can only concatenate list (not "str") to list
    > exec(obj.bytecode)
    2021-01-16 15:50:53 ERROR logics.visual_alarm Logic: logics.visual_alarm, File: /usr/local/smarthome/logics/blinker.py, Line: 62, Method: <module>, Exception: can only concatenate list (not "str") to list
    > exec(obj.bytecode)
    Im Admin Tool unter Logiken wir das Watch Item aufgeführt:
    Watch Items
    Blinker.py wird angezeigt.
    Hat jemand eine Idee?
    Gruß Jürgen
    Zuletzt geändert von Jürgen; 16.01.2021, 22:49.
