ERROR modules.websocket smartVISU
    ich habe eine Neuinstallation mit SHNG 1.9.0 und SV 3.1.0 (Debian / Bullseye) gemacht und dabei umfangreiche Anpassungen der verschiedenen .yaml Dateien vorgenommen (vorher SHNG 1.7.1) soweit aus der Dokumentation und einigen Foreneinträgen ersichtlich.
    Läuft soweit, allerdings bekomme ich ein paar Fehlermeldungen zu denen ich noch keine Lösung finden konnte:
    2021-12-30 14:36:29 ERROR modules.websocket smartVISU_protocol_v4 exception: received 1005 (no status code [internal]); then sent 1005 (no status code [internal])
    2021-12-30 14:49:32 ERROR modules.websocket smartVISU_protocol_v4 exception: no close frame received or sent
    2021-12-30 14:49:46 ERROR modules.websocket smartVISU_protocol_v4 exception: no close frame received or sent
    2021-12-30 14:53:08 ERROR modules.websocket smartVISU_protocol_v4 exception: no close frame received or sent
    2021-12-30 14:53:10 ERROR modules.websocket smartVISU_protocol_v4 exception: sent 1011 (unexpected error) keepalive ping timeout; no close frame received
    2021-12-30 14:54:37 ERROR modules.websocket smartVISU_protocol_v4 exception: no close frame received or sent
    2021-12-30 14:58:23 ERROR modules.websocket smartVISU_protocol_v4 exception: no close frame received or sent
    2021-12-30 14:58:30 ERROR modules.websocket smartVISU_protocol_v4 exception: no close frame received or sent
    2021-12-30 15:01:10 ERROR modules.websocket smartVISU_protocol_v4 exception: no close frame received or sent
    2021-12-30 15:01:20 ERROR modules.websocket smartVISU_protocol_v4 exception: no close frame received or sent
    2021-12-30 15:02:16 ERROR modules.websocket smartVISU_protocol_v4 exception: sent 1011 (unexpected error) keepalive ping timeout; no close frame received
    2021-12-30 15:02:16 ERROR modules.websocket update_item - Error in 'await websocket.send(data)': sent 1011 (unexpected error) keepalive ping timeout; no close frame received
    > Traceback (most recent call last):
    > File "/home/smarthome/.local/lib/python3.9/site-packages/websockets/legacy/protocol.py", line 944, in transfer_data
    > message = await self.read_message()
    > File "/home/smarthome/.local/lib/python3.9/site-packages/websockets/legacy/protocol.py", line 1013, in read_message
    > frame = await self.read_data_frame(max_size=self.max_size)
    > File "/home/smarthome/.local/lib/python3.9/site-packages/websockets/legacy/protocol.py", line 1089, in read_data_frame
    > frame = await self.read_frame(max_size)
    > File "/home/smarthome/.local/lib/python3.9/site-packages/websockets/legacy/protocol.py", line 1144, in read_frame
    > frame = await Frame.read(
    > File "/home/smarthome/.local/lib/python3.9/site-packages/websockets/legacy/framing.py", line 70, in read
    > data = await reader(2)
    > File "/usr/lib/python3.9/asyncio/streams.py", line 723, in readexactly
    > await self._wait_for_data('readexactly')
    > File "/usr/lib/python3.9/asyncio/streams.py", line 517, in _wait_for_data
    > await self._waiter
    > asyncio.exceptions.CancelledError
    The above exception was the direct cause of the following exception:
    > File "/usr/local/smarthome/modules/websocket/__init__.py", line 920, in update_item
    > await websocket.send(msg)
    > File "/home/smarthome/.local/lib/python3.9/site-packages/websockets/legacy/protocol.py", line 619, in send
    > await self.ensure_open()
    > File "/home/smarthome/.local/lib/python3.9/site-packages/websockets/legacy/protocol.py", line 929, in ensure_open
    > raise self.connection_closed_exc()
    > websockets.exceptions.ConnectionClosedError: sent 1011 (unexpected error) keepalive ping timeout; no close frame received
    Ich hab das Thema ansatzweise hier schon mal gefunden aber keine richtige Lösung ableiten können.
    Irgendeine Idee wo das herkommt und was ich ändern muss?
    Marcus
    Zuletzt geändert von bmx; 30.12.2021, 19:24.
    Ich habe das gleiche Problem mit "smartvisu_protocol_v4 exception: no close frame received or sent". Hast du inzwischen eine Lösung?
      Bis auf weiteres kannst Du die Log Einträge „no close frame sent“ vermutlich einfach ignorieren.
      soweit ich das bisher nachvollziehen konnte, machen einige Browser die Websocket Verbindung nicht explizit zu, wenn man auf den Reload Button klickt. Beim Reload der Seite wird eine neue Websocket Verbingung aufgebaut. Das Websocket Modul merkt, dass die alte TCP Verbindung nicht mehr existiert, schließt sie und loggt dieses als Fehler.
      Im develop habe ich den Log Level für diese Meldung bereits auf INFO gesenkt.
      Martin
        Danke, dann ignoriere ich die Meldung.
        Schönen Sonntag noch.
        Christian
          hab seit vorgestern den Log voll mit Einträgen (Die Log-Datei wächst pro Tag auf 790MB)
          das letzte was ich in der Visu gemacht habe, den Widget-Assistent ausprobiert..
          2022-01-25 08:44:05 CET ERROR __init__ modules.websocket.websocket_server smartVISU_protocol_v4 exception: no close frame received or sent -- (__init__.py:smartVISU_protocol_v4:567)
          2022-01-25 08:44:05 CET ERROR __init__ modules.websocket.websocket_server update_log - Error in 'await websocket.send(data)': no close frame received or sent -- (__init__.py:update_log:946)
          > File "/usr/lib/python3.9/asyncio/streams.py", line 721, in readexactly
          > raise exceptions.IncompleteReadError(incomplete, n)
          > asyncio.exceptions.IncompleteReadError: 0 bytes read on a total of 2 expected bytes
          > File "/usr/local/smarthome/modules/websocket/__init__.py", line 943, in update_log
          > File "/home/smarthome/.local/lib/python3.9/site-packages/websockets/legacy/protocol.py", line 920, in ensure_open
          > websockets.exceptions.ConnectionClosedError: no close frame received or sent
            Der Widget Assistant rendert eine ganz normale Visu-Seite, die das im Widget verwendete item beim Backend abonniert. Wenn die Seite geschlossen wird, erkennt shNG in meinen Tests (mit Firefox) zuverlässig das Ende der Verbindung und entfernt den Client. Ich kann mir aktuell nicht vorstellen, wie der WA diese Meldungen auslösen könnte.
            Welches Widget hast Du denn im WA getestet? Ist das Renderer-Fenster noch offen?
            Wolfram
              ungefähr lief das so ab:
              ich hab ein wenig die Intellisense ausprobiert mit basic.stateswitch und ähnlichen, und dabei einen Fehler verursacht z.B. ein Komma zuviel,..
              Error loading Page '[B]assistant[/B]' ! Check config.php -> 'config_pages' for correct Pages/Project configuration or try the [URL="http://10.67.64.52/smartvisu/index.php"]index[/URL] page!
              Danach alles vom Eingabefenster markiert + gelöscht , jedoch die Seite (Tab im Chrome-Bowser) offen gelassen. PC (Win10) in Ruhemodus versetzt und ins Bett gegangen..
